Tail Light Issues
Old Mar 10, 2015 | 08:48 PM
Brian McGuire's Avatar
Default Tail Light Issues
While off-roading, my tail light brush guard got snagged and the entire tail light was pulled off. Nothing seems to be broken and the harness only seems to have come unplugged. Problem is, the plug isn't visible and there isn't any room to reach down to snag it (wherever it may be hiding). Anyone had this happen, and how did you get it out. I'm looking for suggestions before I tear the cargo area apart to get to it.
Old Mar 11, 2015 | 09:48 AM
The inside comes apart pretty easy, pull up the rear sill plate first, then pop off the bottom of the rear side panel and work up. You should not have to pull off the side panel, just reach in from the bottom. When you put it back together just make sure the rubber weather stripping is overlapping the side panel like it was before you started.
If you need more detail with some pics, go here and follow the link to the tutorial for the rear door antenna bracket install. H3 Rear Door Antenna Mount
Old Mar 12, 2015 | 05:25 AM
Thanks, Doc, for the info. Photos helped get it fixed in less than five minutes.
HUM2
Apr 28, 2018 09:42 AM
flrtrader
Nov 29, 2017 01:19 PM
HUM2
Mar 7, 2007 04:33 PM
DWP99
Jul 28, 2006 11:18 PM
nascar 17
Mar 13, 2006 09:23 PM
