T-Case stuck in 4 wheel low
Old Oct 5, 2007 | 09:24 PM
funkDoc's Avatar
Default T-Case stuck in 4 wheel low
Hey All,
I'm new to thses forums and I have 06 H3. I did some searching but couldn't find anything regarding this.
I did some wheeling today and engaged 4 low, and now it wont shift out of 4 low. I have used 4 low in the past and had no problems going back to 4 high. I have tried everything and it simply wont shift out of 4 low. The light never blinks when I push the button. I spent arounf 45 min trying everything with no success.
The car is stuck in vail at the moment so any advice you have would be greatly appreciated.
Old Oct 5, 2007 | 10:02 PM
importkiller's Avatar
Default RE: T-Case stuck in 4 wheel low
did you try going in reverse about 5-10 mph while turning left and right...this should kick her out of 4-low. If not, try going under and unplugging the plugs on the t-case.....clean em out then plug it back in. This connector has given people problems in the past.
Old Oct 5, 2007 | 11:02 PM
funkDoc's Avatar
That's good advice. One thing is that there is no feedback if I push the buttons. They never blink or anything when I push them. I'll do what you mentioned because I did go through some water and mud after going into 4 low. Thanks again.
Old Oct 6, 2007 | 12:00 AM
hilljob26's Avatar
it may be the switch,i know i had a similer problem on my truck
Old Oct 6, 2007 | 07:30 PM
Muddydawg75's Avatar
So... did that fix it?
Old Oct 6, 2007 | 08:19 PM
SteveO's Avatar
I know this may be the obvious but I will ask anyway. Are you putting it in neutral before putting it in low lock?? It needs to be in neutral.
Old Oct 6, 2007 | 09:00 PM
h3carlos's Avatar
So...did it work?
Old Oct 7, 2007 | 10:03 AM
I vote TCase plug fart, might have got gerdoo in the connection, or loose. The switches can go as well? Any luck funkDoc?? ?????
Old Oct 7, 2007 | 04:42 PM
hilljob26's Avatar
when i switched switches,it fixed it,but not sure in your case
Old Oct 10, 2007 | 07:25 AM
pappy44's Avatar
also, make sure the button isn't stuck. It happend to me that way...i must have pushed the button sideways a little, and it got stuck. I felt like an asshat when i figured it out...lol
