Switched Ignition help
Old Jul 22, 2016 | 08:38 PM
groomsxxx's Avatar
Default Switched Ignition help
I am going to be hooking up my trans oil cooler Fan to a switched ignition source. I have ordered a "add a circuit" where I will use one of the fuses. Which fuse would be best to use for switched ignition? Any help would be greatly appreciated.
Old Jul 23, 2016 | 04:30 PM
happythree's Avatar
you can down the manual free,,,search..
Old Jul 23, 2016 | 06:11 PM
groomsxxx's Avatar
I have the manual for fuses ...but which one would be best for using the add a circuit for switched ignition...thats my question.
Old Jul 24, 2016 | 05:53 PM
happythree's Avatar
Default run/crank relay
rel 78 feeds 12v to fuse33 in run mode.
doing wiring you should be looking at a wire diagram so you know what you are doing.
Old Jul 24, 2016 | 07:02 PM
HUMTECH's Avatar
I would use cruise fuse but only to power up a relay for the fan. Use ign power for relay turn on signal otherwise to much draw on circuit
Old Jul 24, 2016 | 07:29 PM
happythree's Avatar
yeah,i assume hes using a relay??
Old Jul 26, 2016 | 03:15 PM
groomsxxx's Avatar
I havent started anything yet. I just have the "add a circuit " I need a little help on the relay setup.
Old Jul 26, 2016 | 05:51 PM
happythree's Avatar
Old Jul 26, 2016 | 06:54 PM
HUMTECH's Avatar
I assume the "add a fuse" is what I would call a fuse buddy? Plugs into fuse location and has 2 fuses in it to create another circuit? If so buy a 4 pin relay and wire the extra circuit from the add a fuse to pin 86 on relay. Pin 85 needs a ground. Pin 30 to battery positive. Pin 87 to fan positive wire. Then add ground circuit to chassis ground from fan. Do all that with battery disconnected to be safe.
Old Jul 26, 2016 | 06:56 PM
groomsxxx's Avatar
yes, its a fuse buddy.. exactly what you said.. thanks for the info.
