Sway bar kit installed
Old Dec 2, 2014 | 06:37 PM
H2Miami's Avatar
Default Sway bar kit installed
I just finished installing the new bushings for the sway bar . Got the kit on Ebay .
the quality is good . Easy to install . Gives some extra clearance and bushing comes with grease fitting .
Hopefully the wiwiwi noise coming from the front end will be gone .
Also fix the rubbing tires on one side cause the bar wasn't centered
I will post again after checking how it performs Sway bar kit installed-20141202_173037.jpg
Old Dec 3, 2014 | 11:16 AM
LoJac963's Avatar
Did you opt for the 1" longer end links?
Link to the ebay auction?
Old Dec 3, 2014 | 03:08 PM
H2Miami's Avatar
Yes .. Not sure if change the way it performs , Imo it should perform better cause the extra inch should make more push on the wheel
so far the wiwiwiwi noise is gone . Been dealing with that noise for years
Ebay link : http://www.ebay.com/itm/331391763620...%3AMEBIDX%3AIT
Old Dec 4, 2014 | 02:53 AM
LoJac963's Avatar
Same kit I've had in my watch list forever. January I hope to start going through my suspension to start replacing parts. The 1" extended end links just provide more clearance. Although I wonder if putting new keys and cranking them up 2-3" changes that at all....
Old Dec 4, 2014 | 07:23 AM
H2Miami's Avatar
"Same kit I've had in my watch list forever" .. LOL same here .. I decide to buy cause the wiwiwi noise was driving me crazy .. Quality was better than expected
Old Jan 21, 2015 | 07:40 AM
Rebuilt57's Avatar
H2Miami:
Did you have to have an alignment done after this replacement? Those replacement units look a lot more robust than the factory stuff.
Old Jan 21, 2015 | 08:16 AM
calif phil's Avatar
No need for an alignment after a sway bar upgrade.
Old Jan 21, 2015 | 08:32 AM
Rebuilt57's Avatar
Thanks for the help Calif Phil.
Old Jan 21, 2015 | 07:32 PM
Man1nboat's Avatar
Those certainly are beeper than the stock ones. How much were they?
Old Jan 22, 2015 | 10:00 PM
H2Miami's Avatar
H2Miami
Oct 23, 2014 07:29 AM
noregret_h3
18
Oct 1, 2010 09:38 PM
ReconH3
Apr 19, 2008 10:50 AM
2zRescue
Dec 21, 2007 02:17 PM
HummerBlues
Sep 27, 2006 05:41 PM
