sut mid-gate
Old Dec 31, 2007 | 04:40 PM
Emanuel's Avatar
Default sut mid-gate
I have a 2006 Hummer SUT mid-gate window will not go down . Fuse is Good. whatcan icheck next.
Old Dec 31, 2007 | 05:51 PM
blackstangs281's Avatar
Default RE: sut mid-gate
Make sure it didn't somehow become unlatched a little by vibration or whatever. If that's not it, take it to the dealer. It's still under warranty right?
Old Dec 31, 2007 | 06:16 PM
importkiller's Avatar
definately agree with the trip to the dealer...but..in case it isn't under warrenty then check out the usual problems with any window...switch,motor,off tracks. Basically the first thing to do is set a volt meter across the motor and hit the switch, if no power is present then the problem is at or before the switch. If motor has voltage then problem is at or after the motor.
Old Dec 31, 2007 | 07:56 PM
Also try the express down switch. Just in case the regular switch is bad.
harleyd629
Apr 27, 2012 07:23 PM
DAGKANA
Jun 27, 2010 08:11 PM
hummernick
17
Mar 21, 2008 02:44 PM
Emanuel
Jan 8, 2008 07:54 PM
