suspesion help
Old May 29, 2008 | 10:13 AM
mani's Avatar
Default suspesion help
guys i got a 03 h2 100mls with rear air ride, back is sagging down all the way looks stupid compressor wont turn on toolift back up, i checked the rear compressor switch in the rear compartmenton/off switch compressor turns on but just to blow up toys etc. anyways took it to the dealer with his tech 2 it showed a code that showed {LEVEL CONTROL AIR PRESSURE CIRCUIT} service guy told me that records showin 06 the driver side level control on the frame was replaced any ideas what the code means or what to checki really need help thankyou
Old May 29, 2008 | 12:02 PM
IHNEVELS's Avatar
Default RE: suspesion help
The service tech that told you this could not tell you how to fix the problem.
Old May 29, 2008 | 07:58 PM
Hummer Guy's Avatar
the system isn't holding air - could be a cracked bag - assuming you can still pump things up w/ the aux pump...
Old May 29, 2008 | 08:10 PM
Gunner_45's Avatar
You are not alone...Just saw one here in Dallas like that.
Old May 29, 2008 | 08:17 PM
alrock's Avatar
Cracked bag - isn't that what Marion Barry carried his crack pipe in?
Old May 29, 2008 | 08:37 PM
mani's Avatar
the aux pump does turn if i want, is that the same pump that pumps up the bags as well? cause the one for the bags doesnt turn on at all, if i unplug the compressor pump in the back of the truck underneathand plug it back in it turns on for 1 sec thats it and where is the fuse located for it thanks guys
Old May 29, 2008 | 10:48 PM
I did a run a few weeks ago with an H2 that had the same problem. His air bag turned out to be fine. The sensor on the top of the frame rail was bad if I remember right.
importkiller
29
Jan 15, 2008 02:51 AM
