Suspension lift update
Old Jan 30, 2007 | 05:22 PM
bmbenear's Avatar
Default Suspension lift update
Just had my local frame and alignment shop install the new Ready Lift kit on my H3 and what a difference. I had originally tweeked the torsion bars to obtain a level look but the ride was awful. I read about the new Ready Lift kit for the H3 and thought I would give it a try. I have got to say, I made the right decision. The look is awesome, leveled front to back and I can't tell a bit of difference from the original ride. Parts and install including alignmentran me 350.00 well spent dollars. I will take a pic and post.
Old Jan 30, 2007 | 05:26 PM
importkiller's Avatar
Default RE: Suspension lift update
sorry you had to spend the cash...turning the t-bars enought to level the ride should not have made the ride much worse. Who ever cranked the bars obviously went to far and had it against the bumpstops, or maxed out your shocks.
Old Jan 30, 2007 | 11:39 PM
07HummerH3's Avatar
ORIGINAL: BMBEBENEAR
Glad it worked out for you. I went with the similar TRUXXX kit and have experienced similar bliss. Leved front to rear and no ride change. There are obviously two schools of thought on which technique is best, but what really matters is that you are satisfied. Looking forward to the pics.
Old Jan 31, 2007 | 01:40 AM
ta8088's Avatar
I'm waiting for some pics as well.
Old Jan 31, 2007 | 01:41 AM
RutDogg's Avatar
Pics Pics Pics!
Old Jan 31, 2007 | 02:56 AM
h3carlos's Avatar
I recently turned my t-bars and I noticed a minor "clank" sound when I go over bumps or turn my wheel all the way to either direction.
Has anyone else experienced this?
Old Jan 31, 2007 | 04:41 AM
how many turns? You may have extended your shocks too much. There is also someone here that installed the leveling kit lift and has teh same clank now. Dilo...did you ever figure out what it was?
If you went 5 or six turns I would look into changing the shocks and see if that takes the noise away, if not look to see if you are against the bumpstop.
Old Jan 31, 2007 | 08:25 AM
h3carlos's Avatar
I made a mark on the bolt and did 3 complete turns counter clockwise, is that too much?
Old Jan 31, 2007 | 09:47 AM
07HummerH3's Avatar
ORIGINAL: h3carlos
After my Leveling Kit was installed I too noticed a "clank" when breaking hard or hitting large bumps. I brought it back to the suspension shop and they lubricated the keys-- problem solved.
Old Jan 31, 2007 | 01:35 PM
h3carlos's Avatar
Where on the keys is the lube needed?
Did they lube it with grease?
