Sunroof operation
Old Jun 2, 2010 | 09:48 PM
canuckh3's Avatar
Default Sunroof operation
I have a 2006...today I noticed when I opened the sunroof, I had to hold the button down...it didnt automatically slide open, same thing with closing, the 'one-touch' operation is gone...and you have to hold the button down. also the button doesnt seem that responsive, you have to hold the button and it takes about a 1/2 second for the roof motor to start. anyone have this issue or can take a stab at what could be wrong?
Old Jun 3, 2010 | 10:55 AM
85_305's Avatar
Banned
Interesting. I'd try taking the battery off and resetting it. But I could be very wrong :P
Old Jun 4, 2010 | 08:39 PM
canuckh3's Avatar
tried it...just screwed up my clock...guess I should have planned and disconnected it just before noon. :P Thought it might be binding rails and the current limit cutout was doing it...so lubed the rails, still notta...wish i had a service manual!
Old Jun 5, 2010 | 07:53 AM
Broken Halo's Avatar
The switch does nothing more then send a signal to the BCM. If the sunroof activates when you press the switch, I would say the switch is probably o.k. It could be a glich in the BCM programing/circuitry.
Old Jun 5, 2010 | 10:00 AM
DTS62284's Avatar
I have an 04 H2 and mine is doing the samething, if you find out whats wrong with yours let me know. If I find out before you do I will let you know. Thanks
Old Jun 5, 2010 | 10:38 PM
canuckh3's Avatar
sounds good, ill probably be booking it in for service at the end of the month
Old Jun 5, 2010 | 11:15 PM
tangodown's Avatar
Not sure how much this helps, but a few years ago (4) I had a Chev Tahoe and had the same thing happen. There is a "programming" step the dealer did and the sun roof worked fine again. Later i found a thread on the steps to reset/reprogram it at home. Sadly, a few months later the sunroof motor failed and would not close at all. I just traded it in at that point.
rklosinski
Jun 12, 2008 09:47 PM
Emanuel
Jan 8, 2008 07:54 PM
H34 pleasure
44
May 4, 2007 04:17 AM
HummerGuy
27
Apr 3, 2007 02:59 AM
iruffneck
17
Mar 4, 2006 01:33 AM
