Sunroof drain question
Old Apr 19, 2011 | 01:51 PM
radioactivesob's Avatar
Default Sunroof drain question
First, I searched the forums and read the other threads...
Question: How do the rear sunroof drains work? Where can I pour water to test their function?
I had a clogged left front drain, blew it out with air, and then tested the rest of the drains. When I opened the sunroof and poured water on the track in front of the right rear drain, I had a little water running out of the drain above the rear tire, but I also had water gushing out of the C-piller where the lower plastic trim meets the upper trim that the seatbelt attaches to.
I took apart my right rear fender and blew air up the tube to make sure it was clear and retested the drain, but it kept leaking.
Any ideas?
Old Apr 19, 2011 | 02:54 PM
drtom's Avatar
Banned
if u can park so that each corner,one at a time, can be tested by pouring water and it runs thru to the wheel area that corner is ok.
if it leaks at one corner,that corner has a bad hose connection,loose,cracked.
headliner time.
Old Apr 19, 2011 | 07:22 PM
That's what I was afraid of... Water comes out the tube, but it also runs down the C-piller. Any advice for taking down the headliner?
bri5150
May 21, 2014 05:37 PM
NJTEX
21
Jul 30, 2012 12:19 PM
Mike
Dec 15, 2010 01:53 PM
Callaway
Jun 3, 2009 03:52 PM
