Stripped Skidplate bolt holes - fix needed
Old Sep 15, 2007 | 02:51 PM
tomp's Avatar
Default Stripped Skidplate bolt holes - fix needed
Exhaust shop stripped out the holes my bolts go into for the skidplate. WHo has faced this and what is the remedy to fix?[/align]
Old Sep 15, 2007 | 02:58 PM
Muddydawg75's Avatar
Default RE: Stripped Skidplate bolt holes - fix needed
shouldn't be too hard to just use a tap and die set to chase the threads again.....
Old Sep 15, 2007 | 08:42 PM
shortbus's Avatar
the dealer has stripped mine, twice. the only option is to drill a slightly larger hole and tap it. i'd recommend a coarse thread, less work to get it started. you may need to widen the hole in the skid plate as well if it's been twisted at all, that makes it easier to get the bolt started. I'm up to a 1/2 inch coarse thread on the rear bolts, and they've already managed to strip one of those. the steel of the frame is soft and thin, there's not a lot to bite into, which makes it easier to strip, but also easier to redo.
Old Sep 16, 2007 | 03:14 AM
You said TAP IT!!!Name:  giggle.gif
Old Sep 16, 2007 | 06:46 PM
Canadians.....
Old Sep 16, 2007 | 10:09 PM
tomp's Avatar
I ended up tapping the holes out and using Time Serts so the stock size bolts would fit. Installed Time Serts with deeper thread depth so the bolts have more to bite on to and installed them with Red Loctite so they won't spin in-out.
Old Sep 17, 2007 | 01:20 PM
glad it all worked out for you....
Justinh
Mar 4, 2014 03:54 AM
HARDxCOR3
19
Apr 11, 2008 03:05 PM
finseeker
Mar 17, 2008 11:59 AM
jm4490
Aug 20, 2007 09:55 PM
shortbus
39
Jul 15, 2007 05:08 PM
