Strange Noise with Roof Lights
Old Sep 26, 2006 | 12:38 AM
canchas's Avatar
Default Strange Noise with Roof Lights
HI Everyone,
My name is Daniel Canchola I have a H3 Adventure I live in Mexico City, two weeks ago a Bought a roof lights after I installed When I drive up to 70 mph strange noises heard in the roof, I need to add extra seal in the front in order to avoid the noise.
I think the problem is when the air crash with the windshield the air up the roof ligts and this produce the noise.
Whis the extra seal in the front I cant hear the noise anymore.
I need to know if someone has the same problem and how do you resolve, and I need to know if oyu have any pictures with the front of roof ligts maybe in order to see if my instalaltions is correct.
Thanks in advance
Old Sep 26, 2006 | 12:44 AM
Dennis's Avatar
Default RE: Strange Noise with Roof Lights
Hola and Welcome Mi amigo!
Your probelm is one I've heard of here on these forums about wind noise and the light bar..
I'm sure you will get an answer soon from someone of our knowledgeable members...Until then, I just wanted to welcome you.
Old Sep 26, 2006 | 12:45 AM
jlock71's Avatar
Yes this is a very common problem< It is why they no longer offer the roof lights at this time , They are redisigning then to correct the wind noise,
Old Sep 26, 2006 | 01:00 AM
inked's Avatar
ORIGINAL: canchas
HI Everyone,
Thanks in advance
Hey canchas, can you post a picture of the roof lights you installed? Were they the marker lights or the off-road lamps?
Old Sep 26, 2006 | 01:10 AM
canchas's Avatar
Thanks for your quickly reply.
I have the marker lights, I dont have pictures but tomorrow I will take some.
Saludos desde Mexico
Old Sep 26, 2006 | 01:46 AM
KTMCanuck's Avatar
Hi,
I have the same lights installed by the dealer. First time they installed them the wind caused them to whistle at anything over 20 km. Took it back for that and other issues and the dealer reinstalled them. Before I took it back from the initial installation you could see a gap between the light trim and the roof. This was especially noticable on the driver side. I was told at the time that they first installed them that GM had tried to correct the noise problem by developing a revised mounting kit, and the dealer was surprised by the wind noise problem. You may want to check to see if you have the lastest version of the mounting kit as the first batch were a real problem.
It ended up that the first installation wasn't completed properly. The rivnuts were loose and the double sided tape was not sufficient to close the gap. After my return visit they tighten all the rivnuts, reinstalled the double tape and added the same tar as is used in sealing gaps in the body of vehicles to the edge of the trim. Since they did that there is no gap at either the front or rear of the light fixture. Additionally the light mounting is super tight against the roof. This work was completed over a month ago and as it rains here quite a bit and the truck sits outside I'm happy to report no more wind noise or leaks. I'll try and take some pics tomorrow to show how tight against the roof the lights are now.
Old Sep 26, 2006 | 12:14 PM
canchas's Avatar
Thanks KTMCanuck and friends (Amigos in spanish)
Please send me some pictures about your installation. my email is jcanchol@mx1.ibm.com
Regards
Old Nov 3, 2008 | 01:07 AM
New2Hummers's Avatar
Does anyone know if Hummer put out a repair kit for the lights, I have a small whistle sound while driving high speeds, we only torqued the rivuts to 35 lbs,yesterday I ran it through a pressure wash, brussless car wash, this thing uses high pressure water to clean the car, and I mean high pressure, I'm surprised it doesn't wash the paint off, anyway it didn't leak any (knock on wood) even with this kind of pressure, we also got the best wash basically meaning they go around the car a couple of extra times, again we got no leaks, the kit however didn't come with any kind of double sided tape. The whistle isn't that bad, in fact I've delpt with louder tires. One thing I would like to do is add ambe lights to the A pillars, the ligths I got are the ones with two white fog lights,. One more quick question how hot do those lights get, my nav system is hosed in the box as the light, I owuld hate to melt it while using the lights, I would think it wouldn't get hot enough to melt the casing of the light bar, so the nav unit should be ok, but ya never know
Old Nov 3, 2008 | 10:36 PM
bonzaiii's Avatar
I have the off road lights and have some whistling but not to bad, It seems to be worse when I remove the covers
force0009
Feb 13, 2013 01:45 PM
pierbranch
Aug 15, 2012 07:42 PM
Cashville
Sep 4, 2011 10:10 AM
H3DONIST
May 25, 2010 03:15 PM
h22005
Feb 11, 2008 03:19 PM
