Stab trac control fail?
Old Jan 3, 2014 | 10:02 PM
LouieB!'s Avatar
Default Stab trac control fail?
I've been searching through old posts but can't seem to find this issue alone.
I was driving over a patches of ice on my way home today and when I hit my brakes I just slid. My traction control light came on and said "stab trac control fail service". Every post I came across had this issue in conjunction with the abs light, where mine was just traction light only.
Any ideas? Where to begin?
Old Jan 3, 2014 | 10:15 PM
LouieB!'s Avatar
Looking a little bit more and found this
https://www.hummerforums.com/forum/h...s-codes-10767/
Going to try to cycle from 4/4hi/4lo an then check the tccm and see if that helps.
Old Jan 4, 2014 | 10:48 AM
LouieB!'s Avatar
Well the trac system fail went away but in the process I fount that while alternating between 4/4hi/4lo that it won't lock into 4lo. The light just keeps flashing on it but won't go steady and it won't click in like it did for the others. Also when I hit my rear did lock there is no audible noise or the light won't go steady.
Any ideas?
Old Jan 4, 2014 | 12:23 PM
happythree's Avatar
diff lock is silent but light on. if no lo lock you cant lock diff.
to lock lo you gotta be in neutral huh.
Old Jan 4, 2014 | 01:11 PM
RKSmith163's Avatar
Was your transmission in neutral and were you going less than 3 mph when you tried to go to 4 low?
Old Jan 4, 2014 | 04:33 PM
LouieB!'s Avatar
No I tried it in D,3,2 and 1 all under 10mph
Old Jan 4, 2014 | 04:35 PM
LouieB!'s Avatar
I didn't know that, but I knew the light should stay steady. I didn't try it in neutral though. Just park and all the drives.
Old Jan 4, 2014 | 06:24 PM
RKSmith163's Avatar
All the instructions are in your Owner's Manual. If you don't have one they can be downloaded at hummer.com
Old Jan 4, 2014 | 07:57 PM
LouieB!'s Avatar
Yeah, I found them. Everything works fine now. Just took a little bit.
Old Jan 4, 2014 | 07:58 PM
LouieB!'s Avatar
Thanks everyone for the help.
Shorty
Jun 23, 2015 09:12 AM
mr.spooky
Oct 25, 2013 03:10 PM
Happy Hummer
Dec 20, 2012 12:10 AM
brachilius
28
Feb 3, 2011 08:04 AM
ockie
Jul 26, 2008 06:44 PM
