Stab system traction failure
Old May 1, 2016 | 05:29 PM
msnyder's Avatar
Default Stab system traction failure
I'm getting a stab system traction failure reduced engine power warning. Been to the Chevy dealer 4 times since January. First two times they reprogrammed my pccm, said if it happens again will need to replace, well it did so they replaced it, had it less than 10 days and it happened again, they kept it for 4 days and nothing. The last 4 days it happens constantly, I turn it off and wait and it sometimes resets or I clear the code. I'm thinking it may be the transfer case shift control module that is in the dash on the passenger side, had the drainage problem there and think it may have contributed to some of this. Need thoughts on this please, driving me crazy.
Old May 2, 2016 | 10:42 AM
Welcome to HF.
The New Member Area is not the place for tech questions, and if it were, you did not specify, year, model and mileage to allow people to possibly provide a useful response.
Old May 2, 2016 | 11:31 AM
msnyder's Avatar
Thanks for the help
Old May 3, 2016 | 11:37 AM
Originally Posted by msnyder
Thanks for the help
No year or Model?
Old May 18, 2016 | 12:15 PM
vacman's Avatar
Mine ended up being the BCM it also got wet, dealer has to program, if u buy used u will end up with other vehicle mileage in my case 125,000 instead of 62,000, one dealer charged 75 dollars to do it, other dealer wanted 1700 for BCM and program
Old May 18, 2016 | 12:20 PM
You have no idea if the OP has an H3 or H2, since he did not bother to provide that info, I would suggest we not bother to guess.
Old May 18, 2016 | 12:28 PM
msnyder's Avatar
It's a 2007 Hummer H3. I replaced the PCCM and the Transfer Case Shift Control Module. Thanks for reply vacman. Doc Olds are you the admin for this site.
Old May 19, 2016 | 06:20 AM
vacman's Avatar
Oh I know, I just went through that nightmare lol I as well replaced all those and more
Old May 19, 2016 | 12:12 PM
Not admin, just a lowly Mod. I will move this to the H3 section where we might get you some additional help.
Welcome and good luck.
Old May 20, 2016 | 07:04 AM
rsc's Avatar
rsc
I had that issue for a few days until I replaced the battery. Low voltage will cause all sorts of issues. Doc will tell you to replace the stock battery terminals while you are in there for best performance.
