Squeaky Drivers Window when opening.
Old Dec 7, 2013 | 07:10 AM
mrjohnp's Avatar
Default Squeaky Drivers Window when opening.
When I open the driver's window it works but there is a kind of dry squeaking/rubbing sound coming from within the door.
Are there some lubes spots I should check?
Hummer 2 140,000km or about 100,000 miles done.
UpDate.
Noise gone now....just needed using.
Old Dec 7, 2013 | 08:24 AM
calif phil's Avatar
You need to pull the door panel off and lube the regulator assy with white lithium grease and then spray silicone lubricant on the rubber weatherstrip where the glass slides into.
You could also have a frayed cable on the regulator and in that case a new one will be required.
Neon
Jan 14, 2013 05:30 AM
yearmax
Sep 3, 2008 08:19 PM
Intercooled
20
Jun 12, 2008 12:44 AM
mr300
Oct 30, 2007 03:06 PM
Ken06H3
Oct 4, 2007 08:17 PM
