Spindle Diameter?
Old Aug 18, 2019 | 12:59 AM
RussW's Avatar
Default Spindle Diameter?
Can anyone tell me the diameter of the 27 spline spindle? I’m looking to Frankenstein a play toy and considering a cv half shaft assembly from an H1.
Ultimately wonder which (if any) 27 spline wheel hub will work. Maybe 95-01 Explorer?
Thanks!
Old Aug 19, 2019 | 09:33 AM
atvspeed4's Avatar
Thanks!
The CV parts interchange with a toyota camry: See the following thread:
https://www.hummerforums.com/forum/h...acturer-30814/
The H1 cv shaft outer spine section does not have a nut like other vehicles to preload the wheel bearing so you would be better off using another cv shaft from a different vehicle. The 1995-1997 S10 ZR2 cv shaft is a common 27 spline outer, much longer shaft than most small trucks and has an easy to use flanged inner tripod joint. They are pretty strong for a 27 spline shaft as well.
Old Aug 19, 2019 | 12:51 PM
RussW's Avatar
Thanks for the info!
CurtisP87
Mar 10, 2015 08:04 AM
hummerlover
Mar 20, 2014 10:58 PM
HoneyBee
Jan 8, 2014 04:58 PM
ingydrummer
Sep 3, 2012 04:44 PM
