speaker problems
hello
i just got my hummer back from the mechanics wh replaced the pump for the brakes and steering and realized as i was driving it home that the speakers ,which are Bose , don't work . No sound comes out of them but the radio display works fine . i can change radio stations or operate the cd player but no sound comes out of the speakers . i would rather not take it back to mechanic if its a simple thing that i can fix myself so if anyone has any suggestions or thoughts on this matter it would be greatly appreciated . thank you very much. |
I would assume that he had to just unplug something. If you do it yourself, I would at least call him. He may know how to tell you exactly where the plug is without you hunting. It would be a pain to disassemble the whole radio console to find a plug right by the fuse box or something.
you might just check the amp fuse first
speaker problem
Originally Posted by drtom
(Post 267330)
The amp fuse is under the hood by the batter it is labeled radio/amp on the plastic fuse cover fuse map. Likely it is just a loose plug I had a similar issue recently and I didn't have the time to take everything apart during the week. I tried a lot of stuff including disconnecting the battery and doing the BCM reset. A few days later I just hit the volume button on a whim and everything has been working fine since.
