SHOX?
Old Apr 28, 2008 | 02:37 AM
Default RE: SHOX?
Ground Force Lowering Kit!!!
Old Apr 28, 2008 | 06:23 AM
REEF_H3's Avatar
Default RE: SHOX?
Forney: I have turned my T-bars about 15 times on each bolt, still not pleases just want to get up a little higher with out buying a lift
Old Apr 28, 2008 | 12:20 PM
GarrettMoore's Avatar
Default RE: SHOX?
Shackles on the rear and keep crankin' the T-bars?
Your driveshaft angles are going to be insane...
Old Apr 28, 2008 | 01:32 PM
big2dabank's Avatar
Default RE: SHOX?
Anyone try the air rides from Arnott? Looks like a cool product if the ride is good.
http://www.arnottairride.com/product...sp?groupId=140
Old Apr 28, 2008 | 01:38 PM
ockie's Avatar
Default RE: SHOX?
ORIGINAL: GarrettMoore
Shocks will not raise your vehicle.
Shocks will allow your vehicle to be lifted with a t-bar crank. They do not "lift" the vehicle on their own, but they are a needed component for a proper t-bar lift.
Old Apr 28, 2008 | 05:32 PM
Muddydawg75's Avatar
Default RE: SHOX?
if installed properly....
Old Apr 28, 2008 | 05:37 PM
Hummer Guy's Avatar
Default RE: SHOX?
Sam Cothrun - one of the co-drivers for Team Hummer has a fab shop, and has some Rod Hall edition Fox shocks -- may want to give them a look:
http://www.samcofabrication.com/prod...products_id=48
Old Apr 28, 2008 | 06:55 PM
Forney's Avatar
Default RE: SHOX?
Don't forget to get your tires realigned after cranking your T-bars or your tires will wear on the outside
Old Apr 28, 2008 | 09:23 PM
REEF_H3's Avatar
Default RE: SHOX?
So what are you guys saying i should do. I have already cranked the T-bars 15 times on each side and im still not pleased with how high my ride sits. i took my nerf bars off but my father got mad and made me out them back, however it defiantly looked better with them off
Old Apr 28, 2008 | 10:12 PM
alphadogg's Avatar
Default RE: SHOX?
The torsion bar adjustment was intended to raise the front end just enough to level the truck. Personally I’ve never heard of anyone turning the bolt 15 times! I turned mine 4 times and raised my front end one inch and then added the Bilstein Cognitos because they provide the extra length that is required instead of over-extending your OEM shocks. (thanks to okie for that info)
This will pretty much answer all your questions:
https://www.hummerforums.com/m_85049/tm.htm
