Servo swap
Old Mar 6, 2018 | 09:56 AM
JerseyCoast's Avatar
Default Servo swap
I tried the search option, but nothing much is showing for H3.
( Maybe my cell phone browser sux).
Any thoughts on this? The Billet or Vette servo swap? I have 2007 H3 Adventurer - auto. I see lots of info on the 355 sites, but not much here on the Hummer side. Is there a disadvantage for H3 vs Colorado, Denali?
As always thanks for your time.
Old Mar 6, 2018 | 10:27 AM
MOVED, this ain't no FAQ.
What prat tell is the "servo" you are talking about.
Old Mar 6, 2018 | 01:33 PM
Trans for firmer shift 1-2, can also go firmer 3-4 from what is being said about it . Better towing ability, cheap easy swap. ( If you believe everything you read on the internet ) .
​​​​​seems to be something popular on the 355 sites, but not much about with the H3's.
Just curious if anybody has done it and if it really makes a difference ? 06-10' H3 are listed as compatable by one vendor who sells it for about $20.
Old Mar 6, 2018 | 02:57 PM
Ordieh's Avatar
Go with Corvette and switch out the plastic 1-2 accumulator piston for a metallic one at the same time (good chance the plastic one will break after the servo swap).
Old Mar 6, 2018 | 03:57 PM
Thank you. Other one looks to be better built, but the Vette option seems to be the consensus . Thanks man appreciate it.
Old Mar 7, 2018 | 07:50 AM
Thought that was what you were talking about, just making sure.
I think you would be better off by getting a PCM Tune, you can select exactly how you want the shifts to be, where the kick down is etc, and a bunch more. If you are planning on getting a tune, forget the servo.
2006-07 Transmissions are controlled by the PCM.
2008+ have a separate Transmission Control Module. When you mail order a tune for them, you also send in the TCM with the PCM.
Then you can tune total performance, not just shift points.
You can also go with a Hypertech for 3.7Ls, or Superchips for V8s, type tuner and change Trans settings on the fly (2008+ trucks).
Old Mar 7, 2018 | 11:03 AM
SuperChips will NOT work with the LH9 in 2010 Alphas. 08-09 Alphas only.
I have read and heard good things about exactly what Ordieh has said on the corvette servos and metal accumulator for 1-2. The 4L60e should already have metal accumulator for the 3-4.
CBphoto had this done during the rebuild of his trans and it shifts crisp, not sluggish (OEM) or violent (shift kit).
The addition of a trans pan with a drain bung welded in too. These will be upcoming upgrades once my warranty expires in May 2018!
Jbrashers
Mar 8, 2016 09:50 AM
jcato
Sep 1, 2008 06:15 AM
t.j.
Mar 18, 2007 12:24 PM
dunkarooos
39
Aug 8, 2006 10:34 AM
aetherH3
Apr 10, 2006 04:49 PM
