Service Stab Stystem failed/ Reduced Power
Old Mar 22, 2017 | 09:31 AM
Originally Posted by Crazyfedexguy
I have a 06 H3 and mine went to reduced power mode off and on for months. A battery disconnect and reconnect seemed to work for awhile until one day it didn't. Took it in and they replaced my throttle body. H3 ran smoother but it went back into Reduced power mode. On a whim I disconnected my Air Mass Sensor flow by the air filter and started it up. The dash still showed Reduced Power mode but the H3 ran like nothing was wrong. I ran some Mass Air Cleaner through the sensor and so far it is running good again but I am always worried now that Reduced power mode is gonna pop up at the worst time. Getting the PCM switched out tomorrow by the dealer but if you're in a bind try disconnecting the mass air flow sensor.
This would be considered a triplicate post, which is more than frowned upon here. Please do NOT continue.
Your blanket statement is not a safe assumption. MAF sensor input plays a role in triggering reduced power mode in only a limited circumstance. It may be important if you would have pulled the code stored in the PCM when the reduced power mode illuminated, but without that code, it is just a guess likely to cause other people more trouble than when they started. There are many other reasons for RPM that have nothing to due with the MAF circuit, we do not want people adding problems that do not exist until we/they know what the actual problem is.
Have the code(s) read, then address possible cause and effect.
jrc1282
Nov 7, 2025 09:16 AM
mskarenbear
21
Jan 8, 2015 02:30 PM
wpduffey
19
Oct 2, 2014 07:14 AM
Jogi
Dec 24, 2012 08:10 AM
carolympus
Sep 13, 2012 07:56 AM
