service air suspension???
Old Nov 27, 2007 | 10:44 AM
CRXMA22's Avatar
Default service air suspension???
well my h2 rear end is sagging, and i seen a warning notice pop up once to service air suspension, the compressor in the back isn't turning on, i'm fearing it's going to cost me a pretty penny to fix, has anyone had this problem, if so is it an easy fix? just replacing the compressor? or is it a domino effect, where everything needs replacing? is there an after market solution? airbags? or a different route?? As far as warranty goes, i didn't buy the extended warranty. [sm=headbang.gif]
Old Nov 27, 2007 | 08:23 PM
djguy988's Avatar
Default RE: service air suspension???
did you check to see if you have a blown fuse?
Old Nov 28, 2007 | 10:06 AM
CRXMA22's Avatar
i checked the fuses in the engine bay, everything checked out fine. is thereanother place i should check? i tried the kickpanel, but only spare fuses were available. i've been doing some reading/research on it, and i believe i
narrowed it down to either the compressor or a sensor that levels the airbags.
just wanted to see if anyone had any first hand experience on the subject so i don't get ripped a new one from the dealer. which is probably inevitable.[sm=rant.gif]
03yellowbee
May 16, 2013 05:48 AM
jdhornbeck
Dec 28, 2010 11:35 AM
rotten
Jun 5, 2010 07:54 PM
rotten
May 30, 2010 06:59 PM
RedRocker
Apr 27, 2009 10:53 AM
