service air suspension???
well my h2 rear end is sagging, and i seen a warning notice pop up once to service air suspension, the compressor in the back isn't turning on, i'm fearing it's going to cost me a pretty penny to fix, has anyone had this problem, if so is it an easy fix? just replacing the compressor? or is it a domino effect, where everything needs replacing? is there an after market solution? airbags? or a different route?? As far as warranty goes, i didn't buy the extended warranty. [sm=headbang.gif]
i checked the fuses in the engine bay, everything checked out fine. is thereanother place i should check? i tried the kickpanel, but only spare fuses were available. i've been doing some reading/research on it, and i believe i
narrowed it down to either the compressor or a sensor that levels the airbags.
just wanted to see if anyone had any first hand experience on the subject so i don't get ripped a new one from the dealer. which is probably inevitable.[sm=rant.gif]
03yellowbee
May 16, 2013 05:48 AM
RedRocker
Apr 27, 2009 10:53 AM
06, 2007, air, compressor, compressors, fix, fuse, h2, hummer, located, location, rear, service, suspension, suspention, suspesion
