Service Air Suspension- 2003 Hummer H2
Old Jul 13, 2016 | 02:37 PM
a_tperkins's Avatar
Post Service Air Suspension- 2003 Hummer H2
Hello,
Recently purchased a 2003 H2 about a month ago. Last week I received the 'Service Air Suspension' message when I was on the freeway. Went off after I started it after work that day, no lowering/sagging or noise from the compressor that I could hear. The message came back on a few days later while on the freeway again. Again, no symptoms that I could see or hear. Just wondering if anyone has an idea of what's going on? Does the H2 need to have the notorious sagging for it to start having issues? Seems to go off after restarting it. So, in the month that I've had it, the message has came on 2-3x with no symptoms.
Thanks for any and all answers!
Old Jul 13, 2016 | 06:28 PM
HUMTECH's Avatar
You need someone to scan air suspension module, code reader wont do it.
Old Jul 13, 2016 | 07:54 PM
certz656's Avatar
I haven't gotten a 'Service Air Suspension' warning yet, but every once and a while I go to the garage and the rear end is sagging, as soon as I start it the compressor comes on and the rear picks up. Not sure the reason this is happening and I am not getting any warnings of an impending problem.
Old Jul 13, 2016 | 08:46 PM
HUMTECH's Avatar
You may have a leak.
Old Jul 13, 2016 | 11:48 PM
a_tperkins's Avatar
So, I used the rear ride height function and raised it during my lunch break. The truck did raise but I couldn't get it to lower before I went home. The light was flashing pretty much the whole ride home (20 miles). I disconnected the battery for about 5 minutes, reconnected and tried to lower it back but the light won't come on at all now. The rear is two inches higher than the front. Tried the rear air compressor attachment and that worked okay (sounded like it). Did I do something wrong when I tried to lower it?
Does there need to be sagging in order to have compressor and/or other issues?
Old Jul 19, 2016 | 04:25 PM
H2CANEPADESIGN's Avatar
Should lower itself while running with all the doors closed. strange that that part doesn't work. The bags themselves rot and will develop small holes that will seep air right where they fold over themselves. I have an 03' and I recently replace my bags for the 2nd time. Seem to last about 6 years. I'm sure that will depend on what environment they are exposed too. The bag replacement is very simple for anyone who has some reasonable mechanical skills. they take about 15 minutes each and cost about 165 each for the original equipment ones. you can get em at the chevy dealer or online.
p.s. DO NOT LET YOUR COMPRESSOR CONSTANTLY RUN!!! It WILL overheat eventually and you will have a VERY expensive repair or will have to get rid of the air suspension (which is a shame if you tow).
Old Jul 23, 2016 | 11:29 PM
fllaw1's Avatar
Default Service air suspension
It can become a pain!
Rear Spring Install airbags are Gone! - Hummer Forums by Elcova
Old Jul 24, 2016 | 11:01 AM
KruBruder's Avatar
It would be nice to have a little light that came on when it is running just to tell if it is running too much.
jdhornbeck
Dec 28, 2010 11:35 AM
rotten
Jun 5, 2010 07:54 PM
rotten
May 30, 2010 06:59 PM
RedRocker
Apr 27, 2009 10:53 AM
CRXMA22
Nov 28, 2007 10:06 AM
