SAVE MONEY please read
ok....... mods maybe you can make this a sticky in h2 SUT and also in here!!! it doesnt seem like much buts its a common problem!!
so you all know i work for hummer...well in the newer h2's they have the brake lights in the rear bumper...a common problem is for the pig tail and socket for the buld to corrode away. per GM you must buy the complete lamp to get the socket..we got crafty and went on an ordering spree and found the socket needed!!!!!!!!! socket is 12335899 and the pig tail connector is 88987995. hope they make this a sticky or everyone takes notes because per GM you must buy the WHOLE LAMP ASY!!! and they are correct but this will work it has the same numbers on it!! hope this helps and saves you guys some money!!!
you would need to get the new bumper ends off like a 2006 or newer! along with the brackets. or i think you may be able to rig something and cut a hole in your old bumper. RH bumper 89026959 LH 89026960 about 150$ each RH lamp is 25952324 and LH is 25952325 and brackets ate 15103571 and 15103572 and those are like12 bucks each. ide try to make your on brackets and cut your old bumper!! try a search!
what's up guys ... i have an 04 h2 with a supercharger. my problem is that.. when i hit the gas sometime..maybe like once day... there's nothing there... it feels like it shut off for a second. or sometime it will go in to limp mode. the dash will read .. reduce enginge power ... the door locks will pop and you hear the chime.... the engine light will come on and the truck has no power.. no matter how hard you step on the gas.. but when i turn it off then start it a few times .. it gose back to normal.... please ... please ... someone ... please tell me what's wrong..... thank you
HummerGuy
21
Dec 28, 2009 06:59 PM
