what did you end up doing with the connectors??? Do you still have them???
Originally Posted by fyr145
(Post 304686)
Was getting dark and running out of time so I just tucked truck side up undrer the bumper panel for now. I am going look and see if the air ride harness is separate from the chassis harness and remove it. The other side of plugs are still on the ****pressor. |
ok cool.
If you do find that it is separate, I could use the truck side harness. I am considering trying to piece together the stock compressor system BUT for use as an on board air system only. I have the air hose, compressor, and bolts, I just need the connectors from the truck side so I can connect it to the compressor by running a separate power circuit from a 12 volt source, then ground it and run the final wiring to the switch. |
rear air suspension
I just removed the rear air suspension on my 2007 H2 SUT, and replaced it with the coil springs, was pretty straight forward and took about three hours to complete, was able to still use the air compressors with the rear air service port in the bed with a few modifications, am very happy with the conversion.
Originally Posted by BAHummerSUT
(Post 306893)
