To Run 37'' nittos
Old Feb 29, 2012 | 04:16 PM
John Morgan Powell's Avatar
Default To Run 37'' nittos
yea im trying to make sure i willbe able to run 37'' nitto muddgrapplers with a 3'' leveling kit front and back? any help please.. e-mail me at johnmorganpowell2292@gmail.com thank you i really appriciate it
Old Feb 29, 2012 | 06:24 PM
08JJ's Avatar
H3, no...H2, should not be a problem.
Old Feb 29, 2012 | 10:47 PM
Can't give you an answer because we don't know what rig you have? H1/H2/H3?
Old Mar 1, 2012 | 02:32 AM
MSHax's Avatar
Here you go! H3 don't try, you'll tear up your fenders when you turn or hit a big bump, but a H2 with a 3" level works well. I used to have 37s on my previous H2 without a lift, not the best idea, but they fit.
Old Mar 1, 2012 | 08:37 AM
Yea I'm talking about a h2 and 37 inch nittos are different than any other 37. The mud grapplers are only sold on 37 13x50.. So I needed to know if I will be able to run the 37" nitto
Old Mar 26, 2012 | 09:49 AM
deathshead's Avatar
I just put them on my H2. I have a little rubbibg at full turn, so I went the cheap way I cut the plastic wheel well a bit.
Old Mar 26, 2012 | 05:22 PM
Caraddict's Avatar
I have 37" nitto mud grapplers on my h2 they rub a little but I can live with it. All I did was torque up the the torsion bars...
Old Mar 30, 2012 | 04:17 PM
MSHax's Avatar
They only rub a little bit? Seems awfully close. What's the offset of your rims? are you rubbing on the sway bar on hard left turns? I was trying to find pictures of my old h2 with the 37s on it, but can't seem to find any, I don't remember it looking so low to the tire. I had to run out and take a quick picture of my current H2 to show you what a cheap 3" eBay lift kit would do for your clearance. The 35s I'm running look small with all that wheel well, it would probably look good with your 37s.
Old Apr 3, 2012 | 01:43 PM
Todd Edge's Avatar
What 3" lift are you referring to(keys & rear coil spring spacer)?
Thanks,
Todd
Old Apr 3, 2012 | 06:02 PM
LoJac963's Avatar
Thanks,
Todd
I'm curious about that also. I had thouhght about going the cheap ebay route also but then thought it would be better to do it right, congnito UCA's and longer shocks to keep everything in alignment
JeepeaterH3
Jun 9, 2010 10:22 PM
h2guy8878
Aug 14, 2008 04:58 PM
mosslager
Jun 3, 2008 08:45 AM
J
Nov 19, 2007 09:42 PM
slingshot
Jul 20, 2007 02:41 PM
