Rubber piece under headlights
Old Mar 21, 2014 | 05:28 PM
LEAFS's Avatar
Default Rubber piece under headlights
Anyone had an issue with the rubber pieces under the headlights. My truck is a 2007,not sure if it's on all years. There a 2 pcs, one under each headight about 24" long. One of mine has popped out of the track that holds it. It's very difficult to get to. I'm hoping I don't have to take part of the bumper off to fix.
Any suggestions.
Thx
Old Mar 21, 2014 | 05:40 PM
wfturner's Avatar
You can access that rubber piece by only removing the front grille.
Two bolts out front and four on the inside engine bay.
Four snaps near the side markers and the whole thing is in your hands
Good luck
Old Mar 21, 2014 | 08:04 PM
motley1987's Avatar
Taking the grille off only takes a couple of minutes. You shouldn't have any trouble at all.
Old Mar 22, 2014 | 05:58 AM
Bunger's Avatar
Yeah, I've had my grill off and on about a dozen times. It's really fast & easy to do.
Old Mar 22, 2014 | 07:54 AM
LEAFS's Avatar
Thanks for the help everyone. Off with the grill it is. Not today though, it's Mar 22 and were expecting 15 cm of snow. Enough with winter.
Old Mar 22, 2014 | 08:33 AM
wfturner's Avatar
Smart choice, to wait until it is warmer. There are two plastic retainer clips on each end of the grille near the side markers, turn signals. These little plastic clips are notorious for breaking for no reason. I am sure cold temperatures may even contribute to that as well.
When all six bolts are removed from grille, grab the grille near the side marker, turn signal area and pul straight toward you.
If you end up breaking any of these clips here is the part number to order more
Part #11561829
Good luck
Old Mar 23, 2014 | 08:51 AM
LEAFS's Avatar
Thanks wfturner
I'll wait till warmer weather. Hopefully in a couple of weeks it will warm up. Thx for the part# too, just in case
motley1987
May 8, 2014 07:39 PM
motley1987
Jan 26, 2014 08:41 PM
ReconH3
16
Apr 17, 2008 03:28 PM
bobopotato
May 8, 2007 01:36 AM
dilo2001gt
16
Oct 30, 2006 12:47 PM
