Royal Purple
Old Jan 14, 2015 | 03:59 AM
hotrod-24's Avatar
Default Royal Purple
Hey Guys
Found some royal purple dealers here and wanted to get all my oils changed, right from the engine, gear box, transfer case and front and rear differentials!
I have googled whats best and no one has a proper answer on what oil the gear box, transfer case and diff's use! I am confused as well.
Can someone help me out here.
I require:
1. Royal Purple Model number of the oil used? if anyone has used em?
2. Any filters other than the engine oil filter to be changed?
Any help with be greatly appreciated!
Old Jan 14, 2015 | 04:03 AM
hotrod-24's Avatar
the guys at Royal purple asked me what Grade oil does the H3 use, are they grades of oil for the :
1. Engine?
2. Gear box?
3. Transfer case?
4. Front and Rear Diff's ?
Old Jan 14, 2015 | 05:56 AM
All that is on your list and more is in the owners manual. If you don't have one you can download one from GM for free.
Old Jan 14, 2015 | 09:25 AM
whylee's Avatar
Since mine is a Alpha with auto trans I can tell you I use 10w-30 for motor, and transfer case the same ATF as trans. Im sure you will use 75-90 for difs.
Old Jan 14, 2015 | 02:16 PM
norinco3264's Avatar
Holy snaps Hotrod, Takes more time waiting for a response than it does to= 1. Go look at your manual 2. download a manual and find the answers.
Lol. btw.. I found the answer from the first link i googled. I'll leave you with the answers for your transfer case. Transfer Case Fluid Change
Old Jan 15, 2015 | 06:01 AM
hotrod-24's Avatar
I will look into it.
Old Jan 15, 2015 | 06:03 AM
hotrod-24's Avatar
Mine is a Auto too. The dealer last changed all oils at 60,000KMS, Major service.
Currently the car is at 116,000KMS going in for major service at 120,000Kms.
Instead of using the regular stuff this time, i wanted to put in some much better performance oil as we do a lot of dune bashing here.
Cooler it is, the better i guess!
Old Jan 15, 2015 | 12:30 PM
Happy Hummer's Avatar
Well can only offer what is been done to gf's and my h3's.
1 trans dexron vi
2 dexcool antifreeze
3 5w 30
I'm to tired lol to type the rest so here goes.....
http://www.hummer4x4offroad.com/forum/showthread.php?1623-Transfer-Case-Fluid-Change
http://www.hummer4x4offroad.com/forum/showthread.php?2446-H3-Diff-and-TCase-oil-Change
Chris
Old Jan 15, 2015 | 04:16 PM
Nmocean's Avatar
I changed all mine over to royal purple. I do know one thing about royal purple, it is all I run in my offshore boat. I made the switch from Mobil one to RP my oil temps dropped 20 degrees and my oil psi went up a few pounds. I run K&N filters with a magnet also.
Old Jan 18, 2015 | 01:28 AM
hotrod-24's Avatar
Hey guys
The dealer won't tell me what exactly they use. The royal purple guys, don't know which ones are required for the diff, transfer case and gear box.
I have a doubt, so does he, and several suggestions online.
bobbarker14
Jul 19, 2015 09:45 AM
Bigunit
Dec 2, 2012 09:39 AM
PJ H2 SUT
Aug 18, 2009 09:39 PM
JNR
Jan 21, 2009 09:09 PM
