Rough idle???
Old Feb 10, 2014 | 03:03 PM
marine6132's Avatar
Default Rough idle???
Hello, I just got me a H3 Hummer, it is a 2008 with 85000 miles. I notice that at idle in gear or not the engine idles so rough it vibrates the steering wheel. So hear is what i've done so far , changed spark plugs , cleaned throttle body, cleaned maf sensor ( mass) , running hgh test gas and also putting heat gas treatment and sea foam , changed air filter. Still have problem , does any one know if I've missed any thing or know what to do? One other question could it be the in tank fuel pump? thanks for any help.
Old Feb 10, 2014 | 04:16 PM
Xlr8n's Avatar
1- Did ya' take the TB all the way off to clean? It needs thoroughly cleaned on both sides.
2- Did 'ya Seafoam before or after the spark plug change? A Seafoam treatment can possibly foul the plugs.
3- Any recent codes?
Old Feb 10, 2014 | 06:43 PM
DaWgPoUnD's Avatar
Correct GAP on the plugs? What kind of plugs? Purchase a new coil pack/install and move it around to different cylinders and see if you have an effect on the issue. Check for vacuum leaks all around. However...the I5 vibrates a little more than "normal" due to its nature....
Old Feb 11, 2014 | 09:28 AM
marine6132's Avatar
Didn't clean both sides of TB , ill try that. There have been no codes. After doing all that I did it did seem to get a little better, but I didn't know that it was normal for this engine. Thanks for the reply.
Old Feb 15, 2014 | 07:37 AM
Kyle0528's Avatar
Could be a bad cylinder head. I have an 08 with 60k and mine crapped the bed. They had soft valves and had to replaced the head. Mine popped an alarm saying misfire of #5 cylinder, but started out with rough idle. Common in the H3.
Llamafood
Jan 11, 2012 07:16 PM
IT_TORK
Nov 30, 2010 10:45 PM
demetri911
Feb 13, 2008 09:37 PM
brachilius
May 4, 2007 06:35 PM
ZX10R
Apr 27, 2007 10:46 PM
