Roof rack cross bar question...
Old Jan 1, 2012 | 09:14 PM
08xcab's Avatar
Default Roof rack cross bar question...
I have a question about the roof rack cross bars. I have a basket that I am contemplating putting on my 06 H3. My problem is this: every so often I have to park in a parking garage that has low clearance for work. Maybe once a month or so. I have some cross bars that I drilled and mounted to the roof channels using some 1/2" bolts with the pan head/square end method. Nice flat washers and nuts to hold the bars on. All stainless hardware, then covered the bolts with some heater hose I cut to fit. Looks great, but now wont fit in the garage, and is not very easy to remove. With the factory cross bars..do they just lift up and off once you unlock them? Or would it be the same as the bolts that I used...I have to loosen them all and slide them to the front of the roof channel. Hope I'm making sence with this. In other words, if I buy a set of OEM cross bars, can I just unlock them at the four mounting points, and lift the whole basket/cross bar assembly off when I need to get in the parking garage?
Old Jan 2, 2012 | 12:02 AM
sandkiwi's Avatar
Assuming they are the same as the 08 cross bars, need to unlock, lurn locking mechanism and then slide to front...probably not what you wanted to hear......good luck...
Old Jan 2, 2012 | 05:44 AM
2wheelmonster's Avatar
sounds like alot of work to get into that parking garage
Old Jan 2, 2012 | 06:43 AM
08xcab's Avatar
Sure does. Maybe I'll sell it and pursue other mods...
JDuncan
Oct 28, 2019 12:55 PM
Broken Halo
Aug 28, 2010 05:39 PM
shopsar.com
Apr 30, 2010 03:56 PM
HPCDAVE
Dec 3, 2008 03:52 PM
Larain60
Feb 10, 2007 09:19 PM
