Roof marker install guide
9 Attachment(s)
Hey guys, I just finished install my roof marker lights, I know that there has been a few threads on this subject, I just wanted add this threadwith step by step instructions to make it easier for some else to do it them selfs and not have to spend the big bucks. It took me about 3 hours to do.
Also, you will see that I only installed 3 out 5 lights, let me know what you think, should I stick with 3 or add 2 more, it's easier to add then plugholes LOL!![8D] Attachment 20227 Attachment 20228 Attachment 20229 Attachment 20230 Attachment 20231 Attachment 20232 Attachment 20233 Attachment 20234 Attachment 20235 |
RE: Roof marker install guide
I don't know, :eek:I'm used to the 5 light look. But yours looks good. Nice pic instructions too.
Nice tutorial. Looks good. Light the light bar rack also.
Great tutorial bear. Light bar looks perfect to me.
H34me |
Thanks guys.
Hey Bear, what did you use to pop the plug out of the inside a-pillar trim without deforming it?
Me and plastic trim pieces don't play well together....hence the question. Oh yeah....3 look good, but 5 would look better. |
Used a smalljewelers screwdriver, it pops out really easy.
http://www.fixitshop.com/Merchant2/g...00003/JS1t.jpg |
Cool....I've got a set of those.
I'd rather ask than experiment and get some undesirable results....;););) Thinking about mounting my Scan Gauge II above the rear-view mirror instead of on the steering column. Hence the need to route a cable under that trim piece. BTW: If you mount two more lights, are you gonna put 'em on the metal or on the plastic corner trim? |
ORIGINAL: Gunner_45 Cool....I've got a set of those. I'd rather ask than experiment and get some undesirable results....;););) Thinking about mounting my Scan Gauge II above the rear-view mirror instead of on the steering column. Hence the need to route a cable under that trim piece. BTW: If you mount two more lights, are you gonna put 'em on the metal or on the plastic corner trim? If I do install the 2 other lights I would put them on the plastic corners. |
Looks good but will look GREAT when you add the 2 other lights to the corners.
