right source of power in dash for device
Old Mar 2, 2009 | 08:00 PM
jdicataldo's Avatar
Default right source of power in dash for device
I am about to install a dvd player in headrest device to my 2006 H3 Hummer and would like to know if using the cigarette lighter outlet as a 12V power source is a good idea. The cigarette lighter power source isn't switched, the the auxgmv3 device would draw power even when the isn't running, correct?
Old Mar 5, 2009 | 03:17 PM
BrickWurX Mfg.'s Avatar
Yep, the DVD would receive constant power. This could drain your battery over time so make sure its not on constantly. Also read your instruction booklet to make sure the DVD player does not draw enough power to blow the fuses for the smokes plug. I think you should be good.
An alternative power choice is the Trailer brake wiring harness under the driver dash on the right hand key side. There is one switched, one ground, on constant, and a break wire in the bundle. most are labeled but use a meter to be sure. This power source has a larger fuse under the hood and is great if you are not planning on hooking up a trailer with a power brake system. Make sure whichever connection you use, you include a specific in line fuse for the DVD. This way you don't end up frying something you don't plan to eat!
Old Mar 5, 2009 | 06:55 PM
jdicataldo's Avatar
Default thanks
the info is usefull. I m not familiar with electric issues so may be it worth to pay to an electrician to do the job. I just thouhgt that I need to splice a wire and that 's it, but seems that I have to be carefull. thanks again.
SedonaBoundH3
Apr 15, 2012 07:22 PM
Gunrunner
Apr 5, 2010 06:50 AM
Autumn Walker
Mar 26, 2010 02:17 PM
maryxie
Oct 13, 2009 05:40 AM
solarflare
Jun 23, 2008 02:50 PM
