Replacing rear shocks
Old Jan 19, 2014 | 07:10 PM
motley1987's Avatar
Default Replacing rear shocks
How hard is it to replace the rear shocks? I haven't seen any write ups on it. Thanks for the info.
Ben
Old Jan 19, 2014 | 09:00 PM
skeeter's Avatar
it is no harder than any other truck shocks. I believe they are even the same part number as a 1500 chevy rear shock
Old Jan 20, 2014 | 02:07 PM
RickStang's Avatar
remove the bolts, remove the shock... install new shock and bolt it up again
Old Jan 20, 2014 | 03:05 PM
Lift vehicle & support the rear axle at ride height.
Remove 2 upper mount bolts.
Remove the lower bolt & nut.
Remove shock.
Install shock.
Install the 2 upper mount bolts, tighten to 26 ft. lbs.
Install the lower bolt & nut, tighten to 70 ft. lbs
With the proper tools, should take around 1-hour.. GL
Old Jan 20, 2014 | 05:03 PM
motley1987's Avatar
Thanks for the help. I've never done shocks before and it seems like every car is different so I wanted to make sure before I got in over my head.
Ben
Old Jan 20, 2014 | 05:13 PM
motley1987's Avatar
Hey Hummerz, I saw in an old post you put Monroe Reflex shocks on yours. Did you raise your front end by cranking the torsion bars and if so, did you put a spacer on the new shock?
Old Jan 20, 2014 | 08:14 PM
Bunger's Avatar
Motley, if you're going to put new shocks on the front, just get the right length. No need to use a spacer on standard length shocks when longer ones are available.
Old Jan 21, 2014 | 10:52 AM
motley1987's Avatar
I had Bilsteins on my last H3, but I'm hoping to go with something a little more budget friendly this time around.
Raffi76
Jul 7, 2015 09:51 PM
Nate2106
Jan 20, 2014 09:36 PM
Widespread Hummer
Jul 15, 2011 12:44 AM
accely
Jan 21, 2011 08:56 AM
BobBreton
Jun 29, 2010 01:09 AM
