Which replacement speakers to get?
Old Apr 27, 2014 | 02:05 PM
hunter8793's Avatar
Default Which replacement speakers to get?
So I got my H3 yesterday! I have found out that the front speakers are kinda messed up.
The passenger side speakers are louder than the drivers side. I have the eq setting right in the middle so both sides should be at equal volume.
I've also noticed that the drivers side door speaker doesn't have nearly as much bass as the passengers side.
The passenger's side sounds alright, but it will make a horrible vibrating sound (like plastic vibrating) on some songs even on relativly low volume.
So I'm hoping that I can just replace the two front door speakers and maybe the driver's side tweeter with oem speakers.
I have found two different oem speaker models.
Which one should I get?
AcDelco 15221426
or
ACDelco 25775451
Thanks.
Old Apr 27, 2014 | 03:04 PM
atari800's Avatar
Old Apr 27, 2014 | 10:06 PM
hunter8793's Avatar
I just tested them again and I think the driver side front door speaker is just not working at all. So what is the difference between the two models that I found? Is one the monsoon version and one just the standard? My H3 doesn't have the monsoon system in it.
Old Apr 27, 2014 | 10:07 PM
hunter8793's Avatar
Old Apr 27, 2014 | 10:08 PM
hunter8793's Avatar
Old Apr 27, 2014 | 10:32 PM
Happy Hummer's Avatar
I've got all four in crate down stairs if you wanted them. There yours. S&h from 53405 to wherever you're at. That's all they will set you back.
Chris
Old Apr 27, 2014 | 11:23 PM
hunter8793's Avatar
Chris
Sounds great! Do you think they could fit in a large flat rate box?
Old Apr 28, 2014 | 07:47 AM
Pm sent.
Chris
Old Apr 28, 2014 | 09:26 AM
The factory speakers are junk, virtually any aftermarket 2, 3, or 4 way replacement would be a huge improvement.
6.5" speakers do not need any adapter to fit. This is a 6.5" Pioneer 3 way mounted in an XTC 6.5" foam baffel (to keep the weather out).
Old Apr 28, 2014 | 09:37 AM
hunter8793's Avatar
I'd like to keep the bass from the factory speakers. I have heard/experienced aftermarket speakers with almost no bass thus the need for a subwoofer arises so I want to avoid that. But if you know of any drop in aftermarket speakers that have as much punch/bass as the factory speakers, please let me know.
