Remove H3 Nerf Bars?
Old Dec 10, 2011 | 09:12 AM
Is_13roken's Avatar
Arrow Remove H3 Nerf Bars?
Can I remove the nerf bars from my H3 without compromising the integrity of the frame/body?
Please be 100% sure.
Thanks.
Old Dec 10, 2011 | 09:13 AM
RGray711's Avatar
Yes they are mostly for looks anyway
Old Dec 10, 2011 | 09:42 AM
Is_13roken's Avatar
Old Dec 10, 2011 | 09:49 AM
RGray711's Avatar
your welcome
Old Dec 10, 2011 | 09:55 AM
Is_13roken's Avatar
Are you 100% sure? I have had some other people on a auto forum say:
"yes
removing that bar will screw up your car, after a few months with it off you will notice the doors will be harder to close
eventually the frame will bend and you will be screwed."
Old Dec 10, 2011 | 10:37 AM
Flash's Avatar
If the other auto forum is for vehicles other than Hummer - you may consider the source of the advice. The Chrome or Black tubular side rails that have a small step area - are commonly referred to as "nerf" bars. These are for decoration and to assist the entering and exiting of the vehicle via the "step". They are not required for the vehicles integrity nor the frames nor the operation of the doors. Remove them if you wish. Definately remove them if you plan to go "offroad". Most offroaders replace the nerf bars and install rocker rails (aka Rock Rails) that protect the underside of the door area against damage from rocks, trees, etc. However for street driving, neither nerf bars nor rock rails are required.
Old Dec 10, 2011 | 10:39 AM
Is_13roken's Avatar
Any ideas on what I should plug the holes with?
Old Dec 10, 2011 | 10:43 AM
Flash's Avatar
Here are a couple pics showing both the Chrome nerf bar and GM OEM rocker rails. Same truck, different bars/rails, neither required.
Attached Thumbnails Remove H3 Nerf Bars?-5742-web-600x400.jpg   Remove H3 Nerf Bars?-6818-web.jpg
Old Dec 10, 2011 | 10:45 AM
Flash's Avatar
If you plan to install Rock Rails I would put bolts into the threads to help prevent rusting. Anti seize might be a good idea as well.
Old Dec 10, 2011 | 10:46 AM
Is_13roken's Avatar
I use it for mudding. should i get rocker bars?
