remove front grille H3 2006
Old Aug 9, 2011 | 02:28 PM
joostie62's Avatar
Default remove front grille H3 2006
Hi,
i am trying to remove the front chrome chrill in front of the radiator.
I have undone the screws but there is a small white plastic clip on both sides.
how do i get these off or release them in order to remove the grill.
thanks guys,
joost
Old Aug 9, 2011 | 02:52 PM
wfturner's Avatar
Pull straight forward
should be two clips per side
Old Aug 9, 2011 | 07:02 PM
joostie62's Avatar
OK got it... nothing broke or damaged...
thanks
Old Aug 11, 2011 | 05:24 AM
2wheelmonster's Avatar
dealing with clips can be a bitch
Old Mar 26, 2012 | 12:36 PM
xca2a1's Avatar
Default Need help removing front grill on '09 H3T
I removed the two nuts from inside and popped the end clips loose but there are still 3 fasteners, on inside each of the grill ribs. I don't want to force them and break something. Does anyone have a suggestion on how to removed these? Thanks!
Old Mar 26, 2012 | 12:42 PM
Broken Halo's Avatar
Besides the 2 nuts you found on the inside, there's also 2 screws on the inside, as well as 2 screws on the outside between the grille slots. Total: 6 fasteners and 4 clips.
To remove the 2 screws on the outside between the grille slots you'll need a socket extension and a 10mm socket.
Old Mar 28, 2012 | 11:42 AM
xca2a1's Avatar
Default Front Grill
Worked great, thanks!
Old Mar 28, 2012 | 12:38 PM
wfturner's Avatar
Keep an eye on those small white plastic clips
They break rather easily, then they wont hold
jeffwhiteis
Jul 19, 2010 01:28 PM
theBroken
Feb 22, 2010 01:28 AM
Cali Man
Jun 5, 2007 05:20 PM
AudialExcursions
Mar 13, 2007 01:31 AM
timtran
Jul 18, 2006 10:28 PM
