Remote Starter
Old Dec 15, 2006 | 03:52 PM
ZYNE's Avatar
Default RE: Remote Starter
Cool, thanks bro, much appreciated!
Old Dec 15, 2006 | 03:53 PM
ZYNE's Avatar
ORIGINAL: importkiller
yup, GMSL2...pretty cool when the temp reaches a certain degree the GMSL2 will automatically turn on your heated mirrors and heated seats...thats awesome!!
http://support.fortinautoradio.com/f...e/autopageinc/
this link shows everything the gmsl2 does for a 2004 hummer h2, don't know what year you have but they are all similiar.
NICE! I'm in an -03 actually .. I believe they are identical ...
Old Dec 15, 2006 | 05:50 PM
Hey, I've been running the Compustar 2W900FMR for about 2 years!! I love it!!
http://www.compustar.org/
Compustar 2W900FMR
Up to 3000* feet of Range
This model was introduced in 2004 as one of the first 900 MHz systems on the marked. It has the largest LCD of any CompuStar remotes along with a built in clock that also displays remote start run time. The 900MHz technology supports a longer battery life and a quicker response time between the transmitter and receiver. Firstech engineers were the first to perfect 900MHz FM for vehicle security applications. The 2W900FMR is available as a 2nd Car controller (blue casing) or a Turbo Timer controller (white casing)
*Range is quoted for U.S. models only. International models will differ in range.
Includes 1 x Two-Way and 1 x One-Way remote
Remote Features
- Two-way paging remote
- Vibrate and audible notification
- Run-time indicator
- Detailed icons
- Turbo timer or 2nd Car
- CompuGlow backlight
- Multi-color LCD (liquid crystal display)
- RPS on/off through remote
- Shock sensor on/off through remote
- Passive on/off through remote
- Valet mode on/off through remote
- Uses standard AAA 1.5 volt battery
- Built in Clock
- Largest LCD of any CompuStar remotes
- 2004 CES Innovation Award Winner
View the manual for the 2W900FMR
This is available in English and French
Alarm Features Starter Features Alarm/Start Features
- Includes dual stage shock sensor
- RPS (remote paging system)
- External Siren (six-tone)
- Super bright blue LED's
- 2-auxillary outputs, expandable to 7 with Channel Expander
- Dedicated trunk release output
- Horn honk output during alarm
- Includes starter-kill relay
- Driver's priority unlock
- Ignition controlled door locks - Factory style alarm
- Dedicated trunk output
- Horn honk output
- Timer start every 1.5 or 3 hours
- Cold start with optional Temperature Sensor
- Includes anti-grind/starter-kill relay
- Manual transmission compatible - Includes dual stage shock sensor
- Includes anti-grind and starter-kill relay
- Trunk release output
- Diesel features built-in
Old Dec 15, 2006 | 05:52 PM
They're coming out with this NEW, IMPROVED version soon. I'm thinking of upgrading cause I like the remote better
This new CompuStar Pro 2W9000FMR remote has a built in clock, in-vehicle temperature readout, and battery voltage sensing. This system operates at a higher frequency to allow for greater range and battery life. Firstech engineers were the first to perfect 900MHz FM for vehicle security applications and we've taken this technology to the next level with the 2W9000FMR Pro.
View the manual for the P2W9000FMR
View the manual for the P1W900FMR
Pro Remote Features
- New multi-color LCD (liquid crystal display)
- Vibration and audible notification
- Clock display with alarm
- Internal vehicle temperature display
- Parking Meter timer
- Button lock
- Timer Start Mode
- Cold and hot starting with temperature
- Run-time indicator (extendable with remote)
- Turbo Timer (extendable with remote)
- Secure Auxiliary Mode
- Passive mode on/off through remote
Pro Alarm Features Pro Starter Features Pro Alarm/Start Features
- Battery backup capable
- Optional super bright blue LED
- Secure valet switch
- Anti-Jacking mode
- Remote Paging System (can unlock vehicle via pin code)
- 2-programmable inputs
- Selectable trunk release output
- Horn trigger output - Includes anti-grind and starter-kill relay
- Factory Style Alarm, monitors doors and trunk
- Time start set on remote by user
- Optional external Siren (six-tone)
- Diesel timer built-in
- Manual transmission compatible - Includes anti-grind and starter-kill relay
- Anti-Jacking mode
SafariHummerH2
Sep 18, 2012 11:31 AM
dilo2001gt
32
Feb 15, 2007 01:37 AM
Rayvyn
Jan 21, 2006 04:01 AM
dilo2001gt
Jan 18, 2006 10:09 AM
Rayvyn
Jan 4, 2006 02:40 AM
