Rear Wiper?
Old Mar 8, 2007 | 08:00 PM
ZX10R's Avatar
Default Rear Wiper?
I noticed the rear wiper doesnt do a complete half circle wipe? Is it like this with all H3's? Or do I have a defective wiper module?
Old Mar 8, 2007 | 08:03 PM
importkiller's Avatar
Default RE: Rear Wiper?
normal.
Old Mar 8, 2007 | 08:07 PM
ZX10R's Avatar
Thanks!!! I was getting worried. Whew!
Old Mar 9, 2007 | 06:50 PM
littlehummerboy's Avatar
When I take apart the rear door to install my rear marker lights, I was planning on looking at the motor to see what would be involved with increasing the sweep distance. I may involve a small mechanical change as well, but guess I'll see what can be done.
Old Mar 9, 2007 | 06:53 PM
more than likely it cannot be changed. it's not like a gear and chain run mechanism where you can change the motion by changing gears or something. It's probably an all in one unit (motor +gear mechanism) that mounts to post that the wiper arm mounts to.
Old Mar 9, 2007 | 08:17 PM
ORIGINAL: importkiller
I'm sure, but I'm kinda Macgyverish with stuff like this, so we'll see.
Old Mar 9, 2007 | 11:12 PM
azz7772's Avatar
ORIGINAL: littlehummerboy
unhook the motor then attach some fishing lineto the wiper arm withsome chewing gum,run it under the rear door some how to the driver compartment so you can manually get the arm to sweep another 6 inches from factory
Old Mar 11, 2007 | 09:08 AM
WOLFGANGSTA's Avatar
or........you could replace the wiper arm with a 2" diameter, loose spring. (like found on the old style storm doors). Then, install the proper electronic device to increase the voltage to the wiper motor. You'll need something with enough power to whip the wiper arm at approximately 84mph. The new device will then flex with the generated speed to allow your wiper blade to bend downward to the left and wipe the entire range of motion!
There! Problem solved.....any other questions?
pduffy
May 3, 2008 05:51 AM
vger105
Mar 21, 2008 08:13 AM
coreyc
Jan 14, 2008 10:00 PM
HummerGuy
May 31, 2007 07:47 PM
bogy
30
Sep 23, 2006 04:04 PM
