Rear Turn Signals flash together
Old Dec 18, 2017 | 07:17 PM
mcsahib's Avatar
Default Rear Turn Signals flash together
Hi all, I am a proud new owner of a 99 H1. I just got the truck and soon find a problem. When I switched the signal light, the front were working fine, but both rear signals will flash together regardless whether I flashed left or right turn. I dont think this is normal, where should I look to fix the problem?
Old Dec 19, 2017 | 08:03 PM
Ian Ward's Avatar
Did the problem start after you replaced the rear lights?
Old Dec 19, 2017 | 10:04 PM
mcsahib's Avatar
Default tail signal
I just bought the car and it come like this, so I have no idea where to check. Also I noticed the two big tail lights wont light up when I turn on the running light, they will only on during braking and both side will flash when I flipped the signal lever.
Old Dec 20, 2017 | 08:48 AM
Ian Ward's Avatar
Sounds like you may have some wiring swapped around. Are the rear tail lights led? Where are you located?
Old Dec 20, 2017 | 08:45 PM
mcsahib's Avatar
Default rear lights
The car is in the shop for fluid change, I can not tell whether they re LED or not now. But I know the front is LED already, so may be they want both side to flash together to increase the load? How do you take out the rear tail light? do I ve to pull the rear wheel well out? I located in Los Angeles.
Old Dec 21, 2017 | 06:31 PM
Ian Ward's Avatar
Is the shop your truck is at Tustan hummer? Mike S is a good tech but i hear tustin raised there labor rate to $200 per hr.
Old Dec 22, 2017 | 12:22 AM
mcsahib's Avatar
Default light
no, i didnt send to Tustin, just a regular shop that i trusted.
another note, the previous owner said the truck run better without abs, so he move the abs sensor out and now i ve the abs and tt4 light on. he said i can just move the sensor back and the light will be off. do u know where is this sensor?
also where is the ecm located?
Old Mar 2, 2018 | 03:01 PM
hichamaziz's Avatar
Bajadreamers
May 5, 2012 09:58 AM
black nite
Mar 1, 2011 06:53 PM
Peej Willys
Apr 25, 2009 09:01 AM
Heysdad
Nov 5, 2007 08:25 AM
hsbertiii
Feb 13, 2007 10:14 PM
