Rear Hatch License Plate Trim Problem
Old Apr 24, 2012 | 06:17 PM
dowork's Avatar
Default Rear Hatch License Plate Trim Problem
Bros -
My rear hatch trim (for lack of a better phrase) - is coming loose. Specifically, the chrome bar across the top of the plate area, I guess it's the light housing. The left side of it can be pulled away from the hatch.
How do I fix this? Is there a clip or something that is accessible by removing the interior panel?
Old Apr 25, 2012 | 08:22 AM
Fireman2020's Avatar
I have the same problem but on the left isde of the bracket. I discovered that the plastic mount had broke, a little 2-part plastic and it is better.
Old Apr 25, 2012 | 08:23 AM
Sorry, mine is the right side.
That is what I get for reading and typing.
Old Apr 25, 2012 | 09:52 AM
dowork's Avatar
So how did you go about the fix? Through the inside by pulling off the trim panel or what? And what is the part called?
Thanks bro.
Old Apr 26, 2012 | 05:45 AM
I removed the inner panel, took the license plate trim off. Pick up some 2 part epoxy from Home Depot, Lowes, Menard. Mix a small portion of the epoxy just to fit the broken piece back on and let it set to harden. Next, I used a piece of heat shrink tubing, cut a piece just a little shorter than the repair part, cover the part and mix some more epoxy and then fill the gap between the tubing and the broken mount and let sit again. End result, you made a plastic cast.
Old Apr 26, 2012 | 07:23 AM
hobcog2000's Avatar
i like your improvising lol
Old Jul 13, 2013 | 04:15 PM
tubacka's Avatar
My license plate/latch cover broke also. Rather than repair or replace the broken parts, as I understand this is a common issue, I drilled 3 holes through the plastic and through the metal inside. Then I ran ss 1" bolts with washers and nuts to keep it secure. While not the standard repair I don't thnik I'll have a problem with it again, and the small bolt heads are not noticeable.
Old Jul 23, 2013 | 03:46 PM
jmudler's Avatar
I did the same thing.........
mcioci
Sep 17, 2014 11:29 AM
jaxtrip
Jan 9, 2011 05:24 PM
solarflare
Jun 25, 2008 10:25 PM
HummerMike
16
Jan 24, 2007 03:17 PM
Linus Gump
Sep 22, 2006 11:01 PM
