Rear End Sag Mystery
Old Oct 21, 2014 | 10:48 AM
  #31
Thunder Cat's Avatar
no... it should not drop at all overnight.. after I installed new air bags on both of my H2s, the height would stay the same, I would check the fittings on top of the bags & make sure they sealed up ,
Old Oct 21, 2014 | 06:29 PM
  #32
rhinomike's Avatar
Ok. I will check the fittings and post my findings.
Old Oct 23, 2014 | 11:39 PM
  #33
rhinomike's Avatar
I checked the fittings. Everything seemed fine.
Old Oct 26, 2014 | 10:14 AM
  #34
rhinomike's Avatar
Consistently about 2 inches low everyday. Any ideas what it could be? There has to be a one way check valve. Maybe it is leaking. Leveling valve?
Old Oct 30, 2014 | 06:41 PM
  #35
sea trout's Avatar
Hello y'all!!!
Were new here and we have a 05 h2 that has the sagging rearend mystery!
We've been readin on here and this thread is awesome.
The chevy dealer told us the compressor was bad and it was a1200 part!
I didn
t think it was right because our h2 pumps right back up when we turn it on and drive it. Then it used to leak overnight, now after the chevy place lifted it it leaks down right after its turned off.
So this thread is spot on.
Y'all mentioned if it's not fixed quick the compressor will go bad.
How do we know when the compressor is bad?
I would assume the back of the car would not pump back up and continue to sag even with engine running.
Would that assumption be accurate?
Cool place y'all, I cant wait to read more!!!
Old Oct 31, 2014 | 12:32 PM
  #36
Correct
Old Nov 4, 2014 | 06:38 PM
  #37
ant69's Avatar
Could temp changes be having an effect on the sag?
Old Dec 26, 2014 | 07:46 PM
  #38
Kenny22's Avatar
Is it dangerous driving hummer at freeway speeds while back end suspension is low due to leaking air bag and compressor turned off.
oceanbrave
Mar 28, 2015 11:40 AM
Kingofhummer
May 12, 2012 05:33 PM
boardergrl
May 12, 2011 07:37 PM
BearClawz
Nov 20, 2010 06:32 AM
johnnyballistic
Jan 6, 2009 04:52 PM
