Rear door panel removal?
Old Jun 20, 2009 | 12:17 PM
blackterror's Avatar
Default Rear door panel removal?
My window came off track and can't get it to roll up. Can someone tell me how to remove the rear door panel on a 03 H2?? Do you need a special tool?....Thanks
Old Jun 21, 2009 | 09:03 PM
Circuitguy's Avatar
A #2 Phillips screw driver and a panel popper tool is all you need.
First remove the screw that holds the square plastic panel to the rear of door opening handle, then remove the two screws above to the rear of this panel that hold the panel to the door, then pop off the small panel extension at the top rear of the panel "no screws on this", then using the panel popper tool start removing the door panel at the bottom front edge, once the panel is up then pull the rest of the panel up by hand all around "will be tight and may break a few clips doing this, this is normal due to the age of the truck, they can be replaced", then unplug the switch wiring, then remove panel from truck, then peel down plastic water barrier from inside of door to get access to window. Done!
I’m not so good at wrighting directions so please call me directly if you need help over the phone.
motley1987
Feb 27, 2014 07:20 PM
aaronballard0033
Jul 15, 2012 10:51 AM
wfturner
Oct 18, 2009 09:20 AM
Ray
Mar 15, 2009 03:32 PM
bmbenear
Aug 23, 2007 03:18 PM
