Rear Door Markers Removal
Old Jun 7, 2012 | 08:41 AM
LIL-TNK's Avatar
Default Rear Door Markers Removal
Hi Guys,
Two of the markers on the rear door of my 2003 H2 have stopped functioning.
Educated guess is they burned out...
Has anyone of you ever worked/ changed such markers?
How do you get access to the bulb?
Please advise.
Old Jun 7, 2012 | 12:45 PM
mgurgone's Avatar
You need to use a small flat head screw driver to push the release pin on the lights and they will pop out. If you look at the black plastic housing around the light there should be a space for you to push in the screw driver releasing the light.
Hope this helps
Old Jun 7, 2012 | 09:30 PM
honda400ex2003's Avatar
mine lifted right out last night with a little tug on them. after they come up there is a turn locking housing that houses the bulb. this housing has the connector clip on it and can be disconnected to release the light housing itself.
194 is the bulb thats in them also, you can get them ready to go for when you change them.
the screwdriver will work to unclip if they are stuck tight. you will have to make sure they have new gaskets or are siliconed again or they will leak. i just had to fix mine last night, i hit the right one while waxing it and broke the stock seal. it started leaking so i had to fix them
steve
aaronballard0033
Jul 15, 2012 10:51 AM
blackterror
Jun 21, 2009 09:03 PM
Ray
Mar 15, 2009 03:32 PM
salil75
Feb 22, 2008 11:57 PM
IgottaH3
Feb 13, 2007 10:13 PM
