Really off topic - electric
Old Jan 16, 2011 | 09:04 PM
Jgrden's Avatar
Question Really off topic - electric
This is something to get our teeth into. We have a 220V outlet under the counter in the kitchen. We just purchased a 110V G.E. convection oven. I want to intall a 220V outlet that a splitter can be plugged into so that there are two 110V outlet plugs and we can plug the oven into one of them. I don't want to change the circut breaker. I am assuming that the 110V is the same there as any other outlet in the house. By not changing the breaker (I don't know the amps.) my only risk is if a short should occur in the oven not tripping the breaker. Right?
Old Jan 16, 2011 | 09:15 PM
Dmentedh3's Avatar
each leg of the (hot) wires carry 110v and yes you will not be protected with the breaker so hook up a GFCI to one leg and the common to the other
Old Jan 16, 2011 | 10:34 PM
Jgrden's Avatar
Which one is the common, white?? There is red, black,and white, plus a smaller gauge green ground wire.
Old Jan 17, 2011 | 09:31 AM
drtom's Avatar
Banned
if its properly wired,red and black are hot,white is common or neutral,grn is ground
the 220 circuit may have a 30 or 40 amp 2 pole breaker. your new cooker may call for a lower amp breaker
the gfi does not provide current overload protection, just leakage. with an overload the big breaker must pop
u can do it but a separate new circuit is best,specially if ever a fire and the inspectors got nosey,,even if your stuff didnt cause it,,u know,,,
they dont like stuff thats rigged up!
Old Jan 17, 2011 | 07:08 PM
Jgrden's Avatar
Thank you drtom. I am thinking you are correct and I will take out the double 50 amp 220 breaker. I am thinking a standard 20 amp 110V will do .
inked
Nov 30, 2012 10:11 PM
2007H3
Aug 14, 2007 04:45 PM
HummerGuy
20
Jun 12, 2007 09:32 AM
HummerGuy
21
Sep 5, 2006 06:11 PM
Greenblade
Aug 2, 2006 12:46 AM
