rattling in headliner over 70 mph?
Old Nov 7, 2010 | 12:51 AM
Rusty_03's Avatar
Default Windshield molding...
I had this problem. It was the top center portion of the windshield moulding/gasket flapping in the air turbulence at the top of the windshield at high speeds.
Old Nov 7, 2010 | 01:34 PM
gunsammo2's Avatar
Originally Posted by luda81
What? explain?
Seems like when it was on fresh air the sunroof would bounce up and down when i put it on rec it would stop.
Old Nov 15, 2010 | 10:31 PM
xcetrachick's Avatar
Default Rattle
Mine also rattles when I'm driving at a high speed. Drives me crazy! Going to try seeing if it is the windshield needing sealant.
Old Nov 16, 2010 | 03:15 PM
scooter996's Avatar
I fixed it awhile ago. It was the 2 black side pieces like I read about. I just pulled them off and used that 3m double sided adhesive and fixed. Its quiet as can be on the highway now
Old Jan 18, 2011 | 05:19 PM
Jdooms's Avatar
What two black side pieces are you referring to? Mine is sooo damn bad that I can't hear the radio. So bad, I'm about to trade it in. I can't find the cause. I've added in some gasket materials where I thought I found some rubbing, but it didn't help.
Old Jan 18, 2011 | 06:47 PM
H2CANEPADESIGN's Avatar
I had the same problem over 65 M.P.H. I cured it with a thin bead of clear silicone at the sides of the windshield under the black rubber, I thought it was the roof racks for the longest time and finally removed them only to find out it wasn't. DOH!
Old Jan 19, 2011 | 11:25 AM
Jdooms's Avatar
That makes sense. I know it's coming from something that is very close to the glass. It sounds like something rattling on the glass on the passenger side. Thought I found it yesterday and installed some gasket material with adhesive and put it back together only to find out I had only quieted it down some. I'm going to put the clear silicone in the corners. That sounds like it would work. Damn sure can't hurt anything. It's bad enough like I said, that I was just going to go get an '08 or '09 and deal with it. Only have 49,000 on this one and hated to do it. May do it anyhow if I can find a good one.
Old Jan 20, 2011 | 03:07 PM
luda81's Avatar
Can someone please post some pictures?????
Old Jan 20, 2011 | 03:29 PM
MARKCORE's Avatar
My dealer said there is a TSB for the AC lines causing this problem. They said they adjusted them, so we'll see! I'll test it tomorrow.
Old Jan 20, 2011 | 04:24 PM
Easy Ed's Avatar
2006 post of mine on the repair of the A Pillar Molding. Hope it helps some here.
http://www.elcovaforums.com/forums/s...ad.php?t=16756
Ed
