Random Stalling Nightmare
Old Jul 4, 2019 | 11:39 AM
Jeff1367's Avatar
Default Random Stalling Nightmare
I Have a 03 H2 that stalls while driving a low speeds can even make it to free way with out It dying on me. I replaced the camshaft position sensor since I need to replace the intake gaskets also the air filter, plugs and wires still the same issues and now seems like it wants to stall at idle revving it up a 1500rpm letting off the gas to let it return to idle then it will fluctuate between 1000 and about 600 rpm then return to a consistent idle again. not sure where to go from here besides checking the fuel pressure at the rails and replacing some coils. Not sure what the spec is for pressure at the rails are? any ideas what would cause this
Just trying to get a few more years out of the 6.0L before I pull the trigger 6.6L LBZ Duramax Swap.
Old Jul 5, 2019 | 07:55 AM
calif phil's Avatar
When you replaced the cam sensor it is imperative to use an OEM quality part. Lots of issues with the cheap parts store sensors. I would suggest to clean the throttle body real good. Any codes stored?
Old Jul 5, 2019 | 10:35 AM
tharber's Avatar
I'd also make sure the MAF is installed correctly and is good.
Tim
Old Jul 10, 2019 | 12:57 PM
Jeff1367's Avatar
I always go with AcDelco replacement parts, haven't had any codes will definitely clean the throttle body also do an all systems scan see if anything will come up possibly related I will update after this
Also had a mention of bad gas because the h2 was sitting for a year before I tried driving it again
Old Jul 10, 2019 | 10:00 PM
legerwn's Avatar
Year old gas will cause issues start there first
egroegart
Aug 18, 2020 08:25 AM
Hbrezzi
Oct 16, 2018 06:44 PM
ethan1893
Jun 23, 2017 07:22 PM
user 956363738
24
Jan 4, 2017 07:11 PM
arcaro
Apr 19, 2016 12:15 AM
