random misfire at idle
Old Jun 14, 2013 | 10:02 PM
pakerosny's Avatar
Default random misfire at idle
Hi I'm new to the forum so hi everybody. I have a problem with my h2 I'm getting a misfire on 4&5 cylinder only at idle. While driving there is no problem at all. I changed spark plugs ,wires, maf sensor, map sensor, injectors, intake manifold and gaskets,cleaned throttle body,cleaned k&n filter,changed fuel filter,did smoke test to check for air leaks, checked cylinder compression it was about 120 psi on all more or less, checked fuel pump. The problem never went away. Check engine light is on and the code is po 300. Drove the truck with the computer hooked up and there is no miss fire only when you stop at the light at idle. Please help, I'm running out of ideas.
Old Jun 14, 2013 | 10:18 PM
Old Jun 14, 2013 | 11:02 PM
pakerosny's Avatar
Thnx i read all the post but it doesn't look like my problem mine happens all the time at idle cold or worm engine and its 2003 hummer h2 6.0 L with 70 000 miles
Old Jun 16, 2013 | 06:44 PM
egroegart's Avatar
Did you change the injectors or just clean them? Everything that I am finding seems to be clogged injectors. But there are several other things to check too. Here's some info on the code.
Automotive Technical Service Bulletin - TSB | Engine-Codes.com
P0300 HUMMER Cylinder Misfire Detected Random Cylinders OBDII Engine Light Trouble Code | Engine-Codes.com
Old Jun 16, 2013 | 10:25 PM
pakerosny's Avatar
I changed them new from the gm dealer
Old Jun 27, 2013 | 11:57 PM
pakerosny's Avatar
OK just an update I finally found the problem it was 2 cracked spark plugs I guess I bought defective ones. Thanx for all your help
Old Jul 1, 2013 | 04:47 AM
AngelNguyen's Avatar
There could be some problem with code have you checked it properly?
Old Jul 1, 2013 | 11:22 PM
egroegart's Avatar
What are you talking about angel? His whole post was about the codes and how he figured out what the problem actually was and then fixed it......READ READ READ
Old Jul 2, 2013 | 12:47 AM
Originally Posted by AngelNguyen
Hi I'm new to the forum so hi everybody. I have a problem with my h2 I'm getting a misfire on 4&5 cylinder only at idle. While driving there is no problem at all. I changed spark plugs ,wires, maf sensor, map sensor, injectors, intake manifold and gaskets,cleaned throttle body,cleaned k&n filter,changed fuel filter,did smoke test to check for air leaks, checked cylinder compression it was about 120 psi on all more or less, checked fuel pump. The problem never went away. Check engine hid headlight kits on and the code is po 300. Drove the truck with the computer hooked up and there is no miss fire only when you stop at the light at idle. Please help, I'm running out of ideas.
ok sorry I am reading it
pm1010
Sep 20, 2019 08:01 AM
hudson4269
Mar 7, 2017 09:12 AM
Pdmiller
Sep 15, 2012 10:09 PM
Calgary
Jul 31, 2010 11:29 PM
fsr7
Feb 15, 2008 10:15 PM
