Check Engine light
Old Dec 22, 2007 | 10:59 AM
badboyz67's Avatar
Default Check Engine light
I had my check engine light come on yesterday and went to the dealer they told me it was a multi firing problem dont rem the code number but when my light came on my speedo went to 120 when i was going 60 mph anyone else had this problem I have a 2003 H2
Old Dec 22, 2007 | 11:09 AM
Muddydawg75's Avatar
Default RE: Check Engine light
Could it have been P0300??
Did the light just flash or did it stay on?
and for what it is worth... I think you have two issues... I think the speedo is just something that happened at the same time...
Old Dec 22, 2007 | 11:49 AM
badboyz67's Avatar
yes that is the code 300 the light did stay on what does that mean?
I am the Jack of all trades and the master of None
Old Dec 22, 2007 | 12:17 PM
If the truck is acting normally... then there may not be anything truly wrong... but..
Do you use cheap gas?
How many miles?
Has it ever been tuned up?
For more info:
http://www.obd-codes.com/trouble_cod...e-detected.php
code P0300 may mean that one or more of the following has happened:
[ul][*]Faulty spark plugs or wires[*]Faulty coil (pack)[*]Faulty oxygen sensor(s)[*]Faulty fuel injector(s)[*]Burned exhaust valve[*]Faulty catalytic converter(s)[*]Stuck/blocked EGR valve / passages[*]Faulty camshaft position sensor[*]Defective computer [/ul]
Old Dec 22, 2007 | 02:56 PM
WOW....Muddy KNOWS ALL!!!! Good Job!!!
Old Dec 22, 2007 | 02:58 PM
Well... remember I posted recently that I stood on it pretty hard and my CEI flashed....
I did a tune up and filled it up with 29 gallon of Sunoco and it never repeated itself... so... I did do a little research...
Old Dec 22, 2007 | 04:06 PM
badboyz67's Avatar
it is stumbling and hesitating but no cheap gas and it has had a tune up with 57k on it
Old Dec 22, 2007 | 09:25 PM
djguy988's Avatar
my check engine light came on last weekend. I purchased an actron cp9180 code reader on sale at the local adv. auto for less than $150. said it was lean bank sensor. I cleared the code and hasn't been on since. figured bad gas. definately a nice piece of equipment to have around for just such an occasion.
Old Dec 24, 2007 | 01:23 AM
HummerUAE's Avatar
actually had mine come on this morning when i started my car , i checked around and saw my gas cap was loose
how can i reset the codes? should i just disconnect and reconnect the battery?
Old Dec 24, 2007 | 07:49 AM
If your cap was off.... and you fixed it... it will go out in a few engine cycles...
if you reset the computer but disconnecting the battery it will also clear... usually.
Poweraidion
Feb 16, 2014 11:26 AM
joenuzz
Aug 21, 2010 10:24 AM
deejaykaygee1
Jan 20, 2010 04:57 PM
jrippel
Nov 29, 2006 08:36 PM
importkiller
Nov 4, 2006 04:02 PM
