Rancho Lift!
Old Jan 14, 2008 | 10:10 PM
saywhat's Avatar
Default Rancho Lift!
I made a appointment to have the Rancho Lift Installed next Monday! 2008 Alpha, Think I will have any issues? Kit says its made for 06-07! And yes I'm adding 36" tires! Please give some feed back! Should I go with larger? 38" Because I got the power! Give some feed back! Thanks
Old Jan 14, 2008 | 10:11 PM
GOFASTER's Avatar
Default RE: Rancho Lift!
I thought the suspension for the Alpha's were modified from the I5's?? Good luck....I hope it turns out great!
Old Jan 14, 2008 | 11:55 PM
azz7772's Avatar
38's are a big heavy tire have you lifted one? i would say that would be hard on your ride i have a suburban with 37.5 mickeys and i have gone through a couple steering boxes and pumps and stabilizer shocks. if you do go with the 38 get the lightest rim you can find without taking away from the strength.
Old Jan 15, 2008 | 12:02 AM
I would make them verify it will fit. Some of the bumpers that fit the 06/07 don't fit the 08 Alpha.
Old Jan 15, 2008 | 05:38 AM
Steve #1's Avatar
There were changes made to the frame for 08 to accommodate the V8. It may not be a smooth install.
It may be worth checking with a parts department to find out what other front endparts were changed for 08.
Old Jan 20, 2008 | 05:45 PM
SteveO's Avatar
[sm=Flahssssss.gif][sm=ttiwwp.gif][sm=Flahssssss.gif]
Old Jan 20, 2008 | 06:10 PM
hilljob26's Avatar
did it ever get installed
Old Jan 20, 2008 | 06:52 PM
importkiller's Avatar
going over a 35 with any amount of lift is not a good idea...the halfshafts and cv joints will not hold up turning 38's. And just cause the alpha has a v8 doesn't mean you have the power....the v8 in the alpha is a small 8 and not the most amazing as far asthe #'s it's putting out. I was running 39's in my dodge and was pushing over 370 hp and it was sluggish...even with gears!
Old Jan 20, 2008 | 08:27 PM
RealJeep's Avatar
Agree with IMPY. The H3 won't be able to last long with 38's, that's big pick-up truck stuff not little SUV tires. You'll definately have to drop the front punkin to keep your half shafts from destroying themselves but IMO the drive line is too mid sized SUV to hold up to big rubber.
If the H3 had a solid front axle then it would probably do just fine but the soccer Mom's wouldn't buy it because it rode too rough. Funny how they compromise tuff for fluff when it comes to 4x4's now days. Even the Jeep has sold out to softie crowd.
Old Jan 21, 2008 | 04:50 AM
hilljob26's Avatar
i think once he gets it all together he will see
