Radio Panel Removal
Old Jun 22, 2012 | 01:34 PM
gotafish's Avatar
Default Radio Panel Removal
Anyone have directions as to remove panel around factory radio,and climate control *****?
Old Jun 22, 2012 | 02:33 PM
wfturner's Avatar
I have a 07, I don't know your model year, but it should be the same
The entire brushed aluminum panel is held in place by spring clips
Put your fingers in the two 12V charge holes at the bottom (to give you a place to grab) and pull straight toward you
It takes a good pull. It should release from bottom first and then you can grab the side and release the top part
Careful, there are wires that are connected to the back, you must disconnect those next
Old Jun 22, 2012 | 02:39 PM
58Bisc's Avatar
If you need pictures do a search on iPod and there will be an install thread for alternative iPod install with picture.
Old Jun 22, 2012 | 03:19 PM
skeeter's Avatar
If you pull up and out it is easier to pull out, but it should come out pretty easily
wfturner
Oct 18, 2009 09:20 AM
blackterror
Jun 21, 2009 09:03 PM
Ray
Mar 15, 2009 03:32 PM
hman969
May 12, 2008 02:13 AM
bmbenear
Aug 23, 2007 03:18 PM
