Quick Heads-Up, when cleaning throttle body.
Old Mar 27, 2019 | 10:56 PM
GrampaEJ's Avatar
Thumbs up Quick Heads-Up, when cleaning throttle body.
Lots of reading, and YT videos, and I hadn't heard/seen any mention of this 'lip' around the butterfly opening.
Weather and work schedule, finally, allowed me to get my TB cleaned, today. Love the smoother idle, and lack of hesitation when coming to a stop.
Where the butterfly seats inside the TB opening, there's a 'lip' (marked in red), for lack of a better name for it. Pay close attention when
cleaning that you get that area completely clean. If not the build up will hold the throttle open, slightly. The longer you go between cleanings,
the more this will build up with carbon.
Old Mar 28, 2019 | 08:05 AM
Banshee32g's Avatar
b12 chemtool is ur friend
Old Mar 28, 2019 | 10:01 AM
I would use TB Cleaner only, it works perfectly.
Old school carb & choke cleaner doesn't cut it very well.
Fuel additives will not clean your TB as no fuel runs through it. Modern TBs are exclusively air only valves.
Old Mar 28, 2019 | 01:07 PM
Doc, That's a work of art! I use CRC 05078, shop towels, soft brushes, and a beer or 2.
Old Mar 28, 2019 | 07:35 PM
WR3NCHE4D's Avatar
Grandpa that is one nasty throttle body. It will cause problems including going into loss power mode. It happened to me twice and never near that dirty. Doc, that is one spiffy clean TB! Better than new.
Old Mar 28, 2019 | 10:46 PM
GrampaEJ's Avatar
Yeah. I knew there had to be a reason for the inconsistent idle.
Practically, wore out a toothbrush, too.
Old Mar 30, 2019 | 01:56 AM
amrg's Avatar
Keep in mind on the newer ones esp the alpha you may or may not need to do a throttle relearn procedure (using a tech2 or hptuners).
Symptoms for needing this would be a stuck higher idle rpm/slow rpm drop after a rev. I had this happen once on my alpha after I cleaned it the first time in 60K and driven 150 miles. I did the I5 several times (06) and never needed the relearn.
Basically throttle blade position needs to be reset so the pcm knows where it sits exactly.
Knightblade
Sep 26, 2016 09:28 AM
flex22
Dec 20, 2015 06:12 PM
skipper55
Jan 31, 2014 03:33 PM
jvorpahl
29
Jan 13, 2014 03:31 PM
jdbaker73
Nov 27, 2011 01:36 PM
